Can i set a switch to invisible?
Hello everyone,
I'm doing an automation controller, which has Auto/Manual mode. In the dashboard, I have multiple switches to control my devives. But in Auto mode, I will not use those switches.
For an elegant solution, is there any way that I can make the switches not visible in Auto Mode?
Not really.
But you could/can disable them. So pressing them won't make anything happen.
If you are adventurous you can look at CSS stuff in a template node and you could make the place where the button/s are be invisible/blank. But it would still take up screen space.
Hi, check this out. I think this is what you want to do.
https://discourse.nodered.org/t/hiding-group-using-ui-control-node-and-button/8567
