Is it possible to enable / disable a node , using a dashboard switch node.?
Hi All,
I would like to know is it possible to enable / disable a node, using dashboard switch node?
For example: If I am using timerswitch node for different schedules of ON/OFF function, at some point of time I would like to use a manual control using a switch node, So if I turn ON that switch, the timerswitch node function should disable.
Thanks In Advance
have you tried a forum search? It seems lie this has come up a few times lately.
No.
But that node seems to have its own mechanism for doing what you want
@zenofmud , Sir yes i did,but could find it.
@cymplecy. Thank you I will look into that
really! did you try using 'disable node' in the search bar?
