Can not get events from slack channel
Hi!
I am using node red in docker with nodered/node-red:latest image.
I am trying to use node-red-contrib-slack 2.0.0 to create a bot able to answer and/or forward messages from a slack channel.
The node slack-rtm-in should be able to detect events like a message on a channel and trigger my flow.
But I can't get it to work.
I created slack apps, current and classic, gave it appropriate OAuth authorisations, allowed incoming webhooks, and tried giving differents token to the slack-rtm-in node, starting with the Bot user Oauth token, but also user Oauth token, the verification token etc...
after all that, nothing works and I can't get the node to react to messages on the channel.
I can send messages to a channel using those same apps and token with the slack-web-out node.
But still no event on the slack-rtm-in node.
Does anyone know how to get it to work?
Thanks a lot,
Best regards,
Thib
