Hi there,
i'm new to nodered. I followed the documents about embedding nodered in an express app, and it worked.
My settings:
var settings = {
httpAdminRoot: "/red",
httpNodeRoot: "/redapi",
userDir: "~/.node-red/",
functionGlobalContext: {} // enables global context
But when i tried to install external nodes in nodered userDir using:
npm install node-red-contrib-mongodb
the installed node did not show in the panel.
When i tried to install using menu, it reports an error:
The express console reported this error:
5 Dec 11:01:29 - [info] Installing module: node-red-contrib-mongodb, version: 0.3.4
5 Dec 11:01:34 - [info] Installed module: node-red-contrib-mongodb
POST /red/nodes 400 5281.048 ms - 86
I did some digging, and found the exact error is:
{ Error: Cannot find module 'node-red-contrib-mongodb'
at Object.getModuleFiles (/Users/zhuxichi/Documents/GitHub/kgserver_v2/node_modules/node-red/red/runtime/nodes/registry/localfilesystem.js:350:19)
at Object.addModule (/Users/zhuxichi/Documents/GitHub/kgserver_v2/node_modules/node-red/red/runtime/nodes/registry/loader.js:395:43)
at Object.addModule (/Users/zhuxichi/Documents/GitHub/kgserver_v2/node_modules/node-red/red/runtime/nodes/registry/index.js:41:19)
at ChildProcess.child.on (/Users/zhuxichi/Documents/GitHub/kgserver_v2/node_modules/node-red/red/runtime/nodes/registry/installer.js:140:52)
at ChildProcess.emit (events.js:182:13)
at ChildProcess.EventEmitter.emit (domain.js:442:20)
at maybeClose (internal/child_process.js:961:16)
at Process.ChildProcess._handle.onexit (internal/child_process.js:248:5) code: 'MODULE_NOT_FOUND' }
It's quite weird because there is no problem when i use a standalone node-red instance. Anything wrong with my settings?
