Can not return results of POST HTTP Request
Been a node red user for some time, but I have finally ran into an issue that seems relatively simple, but I can not find a solution for.
I am running an application on several Raspberry Pi's with Node Red installed on the devices. The application is using a MySQL database connection which is not a good idea on a Raspberry Pi for anything other than development. To get around this I am going to be doing a POST with the ID of the device to a webserver hosting a database. The POST will take the id, convert that into a MYSQL query and return the results in the response. Now I have been able to POST the id, query the DB and return a JSON string, but I can not have that respond to the POST request with the data.
I feel I'm so close to getting this but just cant find the solution. Any help would be wonderful!
Happy to post my flow if it helps. I imagine its something silly im missing.
you can only have one response to each request so the wire that goes from in the http in to the {page node will be causing a problem... Like wise you need to ensure that the other path does maintain the msg.res property all the way down it's path (so it's not lost).
That must be the root cause of my issue. I am taking the message, converting it to a SQL statement, converting the output to JSON, and then trying to send back the JSON response. In this process I am certainly loosing the msg.res.
Am I going about this the wrong way? Perhaps a post response is not the best way to return this type of data?
[{"id":"9cd3bf3f.6b81d","type":"debug","z":"460beebe.2c9c28","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":1030,"y":580,"wires":[]},{"id":"cc647e86.924df8","type":"http in","z":"460beebe.2c9c28","name":"","url":"config","method":"post","upload":true,"swaggerDoc":"","x":130,"y":500,"wires":[["bb35c0fa.ffdf28"]]},{"id":"7da382b1.405fbc","type":"comment","z":"460beebe.2c9c28","name":"Web Listener to return config JSON string","info":"","x":200,"y":460,"wires":[]},{"id":"bb35c0fa.ffdf28","type":"function","z":"460beebe.2c9c28","name":"Record Lookup","func":"/*data = msg.payload.id;*/\ndata = msg.payload.id;\nvar ret = \"data-123\".replace('data-','');\nvar m = {\n topic : \"Select * FROM Perams Where Id = \"  + data +\";\"\n /*topic : \"Select * FROM Perams Where Id =  ('\" + ret + \"');\" */\n };\nreturn m;","outputs":1,"noerr":0,"x":320,"y":500,"wires":[["841c429.6b18f4"]]},{"id":"841c429.6b18f4","type":"mysql","z":"460beebe.2c9c28","mydb":"a1c59403.f234a8","name":"DataGrow DB","x":500,"y":500,"wires":[["1f7ec81.2e4ad38"]]},{"id":"79d540f3.e083a8","type":"change","z":"460beebe.2c9c28","name":"Set Headers","rules":[{"t":"set","p":"headers","pt":"msg","to":"{}","tot":"json"},{"t":"set","p":"headers.content-type","pt":"msg","to":"application/json","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":950,"y":500,"wires":[["c2020b42.36aa4","9cd3bf3f.6b81d"]]},{"id":"c2020b42.36aa4","type":"http response","z":"460beebe.2c9c28","name":"","x":1130,"y":500,"wires":[]},{"id":"1f7ec81.2e4ad38","type":"json","z":"460beebe.2c9c28","name":"","property":"payload","action":"str","pretty":true,"x":670,"y":500,"wires":[["79d540f3.e083a8"]]},{"id":"a1c59403.f234a8","type":"MySQLdatabase","z":"","name":"datagrow","host":"127.0.0.1","port":"3306","db":"datagrow","tz":""}]
a quick look at your first function reveals you are creating a new object (m) to return instead of re-using the existing msg... thus immediately losing msg.res.
Makes sense. However, when I was originally trying to do this i could not sanitize the output to an exact sql statement without loosing the message properties. See below:
If i took out topic: the statement became invalid. If i tried to return msg.topic I also ran into problems.
just add/set the msg.topic as the correct sql you want - and return the msg.
Awesome! I got it working. Thank-you so much for you help. I have attached the finished flow, Also, i found another helpful post:
[{"id":"9cd3bf3f.6b81d","type":"debug","z":"460beebe.2c9c28","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":910,"y":580,"wires":[]},{"id":"cc647e86.924df8","type":"http in","z":"460beebe.2c9c28","name":"","url":"config","method":"post","upload":true,"swaggerDoc":"","x":130,"y":500,"wires":[["c795047a.f77748"]]},{"id":"7da382b1.405fbc","type":"comment","z":"460beebe.2c9c28","name":"Web Listener to return config JSON string","info":"","x":200,"y":460,"wires":[]},{"id":"841c429.6b18f4","type":"mysql","z":"460beebe.2c9c28","mydb":"a1c59403.f234a8","name":"DataGrow DB","x":520,"y":500,"wires":[["1f7ec81.2e4ad38"]]},{"id":"79d540f3.e083a8","type":"change","z":"460beebe.2c9c28","name":"Set Headers","rules":[{"t":"set","p":"headers","pt":"msg","to":"{}","tot":"json"},{"t":"set","p":"headers.content-type","pt":"msg","to":"application/json","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":830,"y":500,"wires":[["9cd3bf3f.6b81d","2319c3af.56e9d4"]]},{"id":"c2020b42.36aa4","type":"http response","z":"460beebe.2c9c28","name":"","statusCode":"","headers":{},"x":1190,"y":500,"wires":[]},{"id":"1f7ec81.2e4ad38","type":"json","z":"460beebe.2c9c28","name":"","property":"payload","action":"str","pretty":true,"x":690,"y":500,"wires":[["79d540f3.e083a8"]]},{"id":"c795047a.f77748","type":"function","z":"460beebe.2c9c28","name":"Record Lookup","func":"data = msg.payload.id;\nmsg.topic = \n\"Select * FROM Perams Where Id = \"  + data +\";\"\nreturn msg;","outputs":1,"noerr":0,"x":300,"y":500,"wires":[["841c429.6b18f4"]]},{"id":"2319c3af.56e9d4","type":"template","z":"460beebe.2c9c28","name":"Format HTML","field":"payload","fieldType":"msg","format":"html","syntax":"mustache","template":"\n{{payload}}\n","x":1020,"y":500,"wires":[["c2020b42.36aa4"]]},{"id":"a1c59403.f234a8","type":"MySQLdatabase","z":"","name":"datagrow","host":"127.0.0.1","port":"3306","db":"datagrow","tz":""}]
