Hello all,
I'm new to node red, but I've been playing with it for hours now.
I want to use the response I get after a post request from the server in te debug messages, but I am not sure how to do it.
Is there a way to use the response so I can handled it different ways? I tried using a HTTP in, passing thorugh a JSON node (the response is in Json), and the a HTTP response, but it does not work and I'm kind of lost.
Thanks.
Ok, I understand now...I can take whatever response I have from the request and de debug node is only to visualize the result in the panel.
So, now I take the response and want to send it back to a PLC, but it says the value is above the permitted range...as you can see, I do not have more than around 100 characteres, any Idea why is it giving me such error?
Thanks.
you dont have a value property in your payload.
use a change node to or function node to take the property you want written to PLC and put it in payload or payload.value (and i would expect you need to convert it from a string to a number. There are 2 javascript functions to help with that : parseInt and Number )
hint: read the PLC nodes built in help
hint2: use the "copy path" button on debug message to get the part of interest.
There’s a great page in the docs (Working with messages : Node-RED) that will explain how to use the debug panel to find the right path to any data item.
final hint...
I recommend watching this playlist: Node-RED Essentials. The videos are done by the developers of node-red. They're nice & short and to the point. You will understand a whole lot more in about 1 hour. A small investment for a lot of gain.
Thanks, Steve.
I kind of solved, but it's true that if I want to do more complicated stuffs I need to follow all the recommendations you are telling me.
Thanks again!
