Can’t login and display blank web Node-RED
Hello all,
I can’t login to Node-RED and it is display blank web Node-Red after login even though the user and password are correct.
Please everyone can help me and resolved issue. thank you so much
A blank web page generally means that an error happened somewhere. Check both your node-red log and the browsers developer console for errors.
And you really should activate windows :wink:
Had similar issue:
I suggest you to update your browser
No I updated browser web firefox but web nodered alway display blank page
So I have checked log error:
2024/07/16 17:21:31 [error] 897698#897698: *26973456 recv() failed (104: Connection reset by peer) while reading response header from upstream, client: 10.2.xx.xx.x, server: app-nred.xxxx.com.vn, request: "GET /settings?=17....... HTTP/2.0", upstream: "http://10.0.x.x:9005/settings?=1....", host: "app-nred.xxx.com.vn", referrer: "https://app-nred.xxxx.com.vn/"
I am having this problem since the Node-red 4 update, running in docker on iHost, using Chrome. On the other hand it runs perfectly in Edge so I'm just waiting to see.
anything browser web are not usable. Meanwhile, a node app running Nodered login normally
I have the same issue after updating to 4.0.2. It works fine on a windows 11 pc using chrome, or on my iphone 13 using chrome or safari, but on my ipad (chrome and also safari) it shows an empty screen, just like is shown here.
I'n running node-red 4.0.2 in a docker on an unraid server.
Is that an iPad with current iOS? (BTW, Chrome has to use Safari's engine on iOS so it is only a different skin in reality).
