Blank web page starting Node-Red
When I start a web browser on my laptop and navigate to the Raspberr PI ip:1880 I can access node-red.
When I am starting Chromium from the PI I get a blank page.
When I run
sudo apt-get install chromium-browser -y
It say that I am on the latest version.
Reading package lists... Done
Building dependency tree
Reading state information... Done
chromium-browser is already the newest version (72.0.3626.121-0+rpt4).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
I have tried Firefox but same results, blank screen.
Any advise will be appreciated, thank you
When you look at the browser console when it is working from the PC do you see the Monaco error there?
Did you wait quite a long time when running the browser on the Pi? Some models of the Pi are underpowered for driving a browser.
Waited some time, I know the PI are lacking horse to do the job.
Only error from the PC is map
Are you absolutely certain that you are connecting remotely to the correct pi? I have several times had strange issues, only to realise the Pi I am connecting to is not the one I thought it was. Stop node red on the locally connected screen and make sure the remote one fails.
A long shot, but is your pi all up to date? Run this to make sure
sudo apt update && sudo apt full-upgrade
then reboot and try again.
I have only one active, and have rebooted it several times.
This install is +/-3 days old (OS + Node-red + Grafana + InluxDB), have run both those today.
pi@raspberrypi:~ $ sudo apt update
Hit:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease
Hit:2 http://archive.raspberrypi.org/debian stretch InRelease
Hit:3 https://repos.influxdata.com/debian stretch InRelease
Hit:4 https://packages.grafana.com/oss/deb stable InRelease
All packages are up to date.
pi@raspberrypi:~ $ sudo apt full-upgrade
Calculating upgrade... Done
pi@raspberrypi:~ $
If it is a new install, why are you using an out-of-support version of raspbian?
32
armv7l
pi@raspberrypi:~ $ cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)"
NAME="Raspbian GNU/Linux"
VERSION_ID="9"
VERSION="9 (stretch)"
VERSION_CODENAME=stretch
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
Stretch is out of support.
Thank you my bad
Are you going to upgrade and see if that fixes it?
Rewrite the image and just reload every thing
Thanks for your help @Colin
vncviewer_U9FBBCgser
Thank you
