Dont show node red interface in web browser
I have used node-red in a "raspberry pi" before and it works ok. Now i want to use it in a ubuntu 18.04 OS. I have followed the tutorials in internet, but when i try access through web browser, this cant connect.
Someone knows why it happen?
Start Node-RED
Once Node-RED has started, point a browser at http://(My ip):1880
On Pi Node-RED works better with the Firefox or Chrome browser
Use node-red-stop to stop Node-RED
Use node-red-start to start Node-RED again
Use node-red-log to view the recent log output
Use sudo systemctl enable nodered.service to autostart Node-RED at every boot
Use sudo systemctl disable nodered.service to disable autostart on boot
To find more nodes and example flows - go to http://flows.nodered.org
Starting as a systemd service.
30 Jun 03:07:08 - [info]
Welcome to Node-RED
30 Jun 03:07:08 - [info] Node-RED version: v0.20.6
30 Jun 03:07:08 - [info] Node.js version: v10.16.0
30 Jun 03:07:08 - [info] Linux 4.15.0-54-generic x64 LE
30 Jun 03:07:08 - [info] Loading palette nodes
30 Jun 03:07:09 - [warn] rpi-gpio : Raspberry Pi specific node set inactive
30 Jun 03:07:09 - [warn] rpi-gpio : Cannot find Pi RPi.GPIO python library
30 Jun 03:07:10 - [info] Settings file : /home/victor-t/.node-red/settings.js
30 Jun 03:07:10 - [info] Context store : 'default' [module=memory]
30 Jun 03:07:10 - [info] User directory : /home/victor-t/.node-red
30 Jun 03:07:10 - [warn] Projects disabled : editorTheme.projects.enabled=false
30 Jun 03:07:10 - [info] Flows file : /home/victor-t/.node-red/flows_home_melserver.json
30 Jun 03:07:10 - [info] Creating new flow file
your credentials.
30 Jun 03:07:10 - [info] Starting flows
30 Jun 03:07:10 - [info] Started flows
30 Jun 03:07:10 - [info] Server now running at http://127.0.0.1:1880/
I have resolved it. The problem was with the firewall, you can use sudo ufw allow 1880, and then it works
