Node-RED Raspi refuses connection when i try to connect with my PC browser
I just installed and started Node-RED on my raspberry pi for the first time and (and least to me) it doesn't look like there's any major issues with running.
pi@raspiLV:~ $ node-red-start
Start Node-RED
Once Node-RED has started, point a browser at http://192.168.0.118:1880
On Pi Node-RED works better with the Firefox or Chrome browser
Use   node-red-stop                          to stop Node-RED
Use   node-red-start                         to start Node-RED again
Use   node-red-log                           to view the recent log output
Use   sudo systemctl enable nodered.service  to autostart Node-RED at every boot
Use   sudo systemctl disable nodered.service to disable autostart on boot
To find more nodes and example flows - go to http://flows.nodered.org
Starting as a systemd service.
25 Dec 10:15:07 - [info]
Welcome to Node-RED
25 Dec 10:15:07 - [info] Node-RED version: v2.1.4
25 Dec 10:15:07 - [info] Node.js  version: v14.18.2
25 Dec 10:15:07 - [info] Linux 5.10.17-v7l+ arm LE
25 Dec 10:15:08 - [info] Loading palette nodes
25 Dec 10:15:09 - [info] Settings file  : /home/pi/.node-red/settings.js
25 Dec 10:15:09 - [info] Context store  : 'default' [module=memory]
25 Dec 10:15:09 - [info] User directory : /home/pi/.node-red
25 Dec 10:15:09 - [warn] Projects disabled : editorTheme.projects.enabled=false
25 Dec 10:15:09 - [info] Flows file     : /home/pi/.node-red/flows.json
25 Dec 10:15:09 - [info] Creating new flow file
your credentials.
25 Dec 10:15:09 - [info] Server now running at http://127.0.0.1:1880/
25 Dec 10:15:09 - [info] Starting flows
25 Dec 10:15:09 - [info] Started flows
But when i try to connect to http://127.0.0.1:1880/ on my PC browser it just gives me "ERR_CONNECTION_REFUSED"
I have tried to safe start it because that seems to be a common solution when you can't connect, but in safe mode i get the exact same results.
Thank you in advance for anyone willing to help.
Hi @LouisV,
Welcome to the forum.
You need to use the IP address of the Pi in place of 127.0.0.1.
The 127 address is always the local address of the computer you are using. So you'd use that address if you were running the browser in the same device as Node-RED.
This message could be made more helpful by including the server IP address instead of 127...
I know it does quote the real IP address earlier in the startup output.
