Hi guys, I was installing a new node when "access to server lost appeared" in the browser. Since then, I couldn't have Node Red work properly, and the following error is showing in the logs:
Error: connect ECONNREFUSED 127.0.0.1:6668
at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1144:16) {
errno: 'ECONNREFUSED',
code: 'ECONNREFUSED',
syscall: 'connect',
address: '127.0.0.1',
port: 6668
So I guess my Raspberry Pi is not connecting to the port? Is it safe to open the port? My Pi is connected to a rooter which is behind my internet modem. I prefer to ask since I've got almost no clue in network security
Thanks for your help!
Hugo
what node did you install?
Or was it a demo flow you pasted in?
Either way, it has possibly crashed node-red.
Assuming you installed node-red using the official script, try this...
node-red-stop
node-red --safe
- refresh your browser (F5)
- remove the bad flow / node
- deploy
- exit the running
node-red (CTRL+C)
- start node-red service
node-red-start
It worked perfectly. Thanks. The node is "node-red-contrib-apple-tv-x". I will try a second install, and if no luck I will report. Thanks for you quick help
Did you see the install instructions in the readme? Also it has not been updated in two years and there are several unanswered issues on the node's github page, so I would not be surprised if it no longer works.
Colin, I think you are referring to "node-red-contrib-apple-tv" not "node-red-contrib-apple-tv-x" like the op mentioned. node-red-contrib-apple-tv-x doesn't mention the prerequisites and was published/updated 2 days ago
Yes, you are quite right, zero marks to me for paying attention.
No worries
The issue is reported. Thanks for your help guys!
