Error: connect ECONNREFUSED
randomly, one a month, two months, my node-red crash (and consequently my home automation go down).
The error is (by the terminal)
3 Jan 22:41:38 - [red] Uncaught Exception:
3 Jan 22:41:38 - [error] Error: connect ECONNREFUSED 52.214.227.89:443
    at TCPConnectWrap.afterConnect [as oncomplete] (node:net:1278:16)
Can I avoid the crash at least?
Are there more lines in the error trace or is that it?
No, no more lines ....
What version of nodejs is this using?
What is the node-red version?
Does this happen randomly or when you perform a specific action?
What is the environment like (docker install? Direct install?)
Do you recognise the IP (is it a my SQL or some other dependant service?)
3 Jan 08:35:02 - [info] Node-RED version: v3.1.1
3 Jan 08:35:02 - [info] Node.js version: v16.20.2
3 Jan 08:35:02 - [info] Linux 5.15.32-v7l+ arm LE
Randomly... yesterday at 22:41:38 absolutely no activity or action
Direct install on Raspberry Pi4 - SO raspberry
Absolutely no!
The IP refers to Amazon Alexa ...
Therefore Alexa-remote2-applestrudel is the problem .....
I have the same problem. Did someone find a solution for this?
No, I didn't find any solutions .....
Assuming this is the correct repository, it has not been reported (and therefore probably wont get fixed)
