hacj
1
Hello, I'm new in node-red and javascript.
I created a flow for my project. I have a lorawan gateway. I can develop applications with node red on this gateway. But I'm stuck here.
As it can be seen in the picture, I cannot dynamically change the eui and payload values. How can i change these values dynamically.
What is the exact name of this node?
Please link to it from flows library
hacj
3
It is not in the flows library. It comes with gateway. The name looks like this; node-red-contrib-node-library : LoRa Input
Then i cannot check the source code to help you.
Have you looked at the built in help on the side-bar for this node?
Have you been in touch with the MFG of this device?
PS, what gateway device is this?
iiLaw
6
Hi it's a limitation of the way Milesight have developed the node.
I share your frustration!!
The only LoRaWAN GW with onboard LNS/Node-RED that will do what you want is a Multitech AEP
