I had to reinstall influxdb but unfortunately I forgot to update node-red-contrib-influxdb nodes so now I am not able to access to nodered UI.
Looking at logs it tells:
at new RequestError (/data/node_modules/influx/lib/src/pool.js:52:28)
at IncomingMessage.<anonymous> (/data/node_modules/influx/lib/src/pool.js:62:53)
at emitNone (events.js:110:20)
at IncomingMessage.emit (events.js:207:7)
at endReadableNT (_stream_readable.js:1047:12)
at _combinedTickCallback (internal/process/next_tick.js:102:11)
at process._tickCallback (internal/process/next_tick.js:161:9)
12 Feb 14:56:02 - [error] [influxdb out:3de57654.f35602] Error: A 401 Unauthorized error occurred: {"error":"authorization failed"}
So I tried to remove node-red-contrib-influxdb but now the logs tells:
12 Feb 14:56:17 - [info]
Welcome to Node-RED
12 Feb 14:56:17 - [info] Node-RED version: v0.19.5
12 Feb 14:56:17 - [info] Node.js version: v8.1.3
12 Feb 14:56:17 - [info] Linux 4.14.94-v7+ arm LE
12 Feb 14:56:18 - [info] Loading palette nodes
12 Feb 14:56:33 - [info] Dashboard version 2.13.2 started at /ui
12 Feb 14:56:34 - [warn] Missing node modules:
12 Feb 14:56:34 - [warn] - node-red-contrib-influxdb (0.2.2): influxdb, influxdb out, influxdb batch, influxdb in
12 Feb 14:56:34 - [info] Removing modules from config
12 Feb 14:56:34 - [info] Settings file : /data/settings.js
12 Feb 14:56:34 - [info] Context store : 'default' [module=memory]
12 Feb 14:56:34 - [info] User directory : /data
12 Feb 14:56:34 - [info] Server now running at http://127.0.0.1:1880/
12 Feb 14:56:35 - [info] Active project : node-RED
12 Feb 14:56:35 - [info] Flows file : /data/projects/node-RED/flows.json
12 Feb 14:56:35 - [info] Waiting for missing types to be registered:
12 Feb 14:56:35 - [info] - influxdb
12 Feb 14:56:35 - [info] - influxdb out
and in the same way the UI is unaccessible:
Is there any way to fix this?
