"Cannot GET/" No GUI
I cant access the GUI. Usually if there was an error, it would display after the / but there's nothing
For some reason, im able to access it on another pc on the same network but not locally?
  • how are you running Node-RED?
  • have you modified the httpAdminRoot property in the settings file? Or any other changes to the settings file?
  • any error messages in the Node-RED startup log?
    Im on windows 10. I ran it through cmd
    No editing of any file. The only troubleshooting iv tried is reinstalling node-red
    Nope. As far as i know, there's no errors here.
Also one weird thing is that I am able to access node-red using another a computer on the same private network. Don't know if that's related or not
In that case it is not a node-red issue but an issue with the machine it is running on accessing localhost. Does it work if you use http://127.0.0.1:1880?
Also does it work if you use the IP address (or whatever you use from the other machine)?
Both localhost and 127.0.0.1:1880 will return the cannot get/ error
  • Also does it work if you use the IP address (or whatever you use from the other machine)?
Yes it does. I am able to access node-red terminal by using the node-red host ip.
To clarify, lets say machine 1 is running node-red and its ip is 192.168.1.2
I am unable to use machine 1 to view node red with localhost:1880 or http://127.0.0.1:1880
but I am able use machine 1 node-red from other machines by using 192.168.1.2:1880
What browser are you using? Can you try a different one?
Hello @subwayfootlong ,
did you try http://localhost:1880/ui/?
Cheers
Ranki
What happens if - on machine-1 - you open a terminal window and use
ping 127.0.0.1 -c 3
If it doesn’t work then something on the device is blocking access
