Cannot get /report.html
I would like to ask.
I have file in C:\users\nxf68958\.Node-red\report.html
And when I would like to open this file by: localhost:1880/report.html I get: Cannot GET /report.html
in Log I have: "Nov 09:52:00 - [info] User directory : \Users\nxf68958\.node-red"
I am using: NR: 3.0.2 Node: 18.12.0
It worked perfectly on older versions of: NR: 2.2 and Node: 16.13. Then I actualized and it stopped working.
In settings.js is option: "fileWorkingDirectory" I tried to change it, but without change. What am I doing wrong?
Thank you
Check your settings.js file on the old install. You likely had a httpStatic entry and forgot to add this to the new installation.
Oh, thank you very much for response.
On old settings.js the httpStatic does not exist at all.
I Added it there by
httpStatic:__dirname
, and It working well.
Thank you.
