Cannot hide a dashboard TAB that has a spacer
This particular environment:
28 Sep 23:07:55 - [info] Node-RED version: v0.20.7
28 Sep 23:07:55 - [info] Node.js version: v8.11.1
28 Sep 23:07:55 - [info] Windows_NT 10.0.17763 x64 LE
28 Sep 23:08:03 - [info] Dashboard version 2.16.3 started at /ui
spacer
When i disable the flow that has a dashboard TAB I expect that this TAB will be automatically hidden in the dashboard (assuming TAB is not used in any other flow). This is not happening when the TAB that has a spacer inside a group. Removing the spacer it works as expected.
Anyone can reproduce ?
If you disable the group it will not show on the dashboard
