Cannot install node max31865 from repository
Hello. Unable to install node node-red-contrib-pi-max31865 0.9.4 from repository. Any ideas?
With node version 19 everyting is ok, but now i have version 20.
Here is the log file. Thanks.
2023-04-26T13:52:53.847Z Install : node-red-contrib-pi-max31865 0.9.4
2023-04-26T13:52:56.554Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production --engine-strict node-red-contrib-pi-max31865@0.9.4
2023-04-26T13:52:58.843Z [err] npm
2023-04-26T13:52:58.844Z [err]
2023-04-26T13:52:58.844Z [err] WARN config production Use `--omit=dev` instead.
2023-04-26T13:53:08.971Z [err] npm
2023-04-26T13:53:08.972Z [err]  ERR! code 1
2023-04-26T13:53:08.973Z [err] npm
2023-04-26T13:53:08.974Z [err]  ERR! path /mnt/dietpi_userdata/node-red/node_modules/spi-device
2023-04-26T13:53:08.981Z [err] npm ERR!
2023-04-26T13:53:08.982Z [err]  command failed
2023-04-26T13:53:08.982Z [err] npm ERR! command
2023-04-26T13:53:08.983Z [err]  sh -c node-gyp rebuild
2023-04-26T13:53:08.984Z [err] npm ERR! gyp info it worked if it ends with ok
2023-04-26T13:53:08.984Z [err] npm ERR! gyp info using node-gyp@9.3.1
2023-04-26T13:53:08.986Z [err]  ERR! gyp info using node@20.0.0 | linux | arm64
2023-04-26T13:53:08.986Z [err] npm ERR! gyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"
2023-04-26T13:53:08.986Z [err] npm ERR! gyp info spawn /usr/bin/python3
2023-04-26T13:53:08.986Z [err] npm ERR! gyp info spawn args [
2023-04-26T13:53:08.986Z [err] npm ERR! gyp info spawn args   '/usr/local/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',
2023-04-26T13:53:08.986Z [err] npm ERR! gyp info spawn args   'binding.gyp',
2023-04-26T13:53:08.986Z [err] npm ERR! gyp info spawn args   '-f',
2023-04-26T13:53:08.986Z [err] npm ERR! gyp info spawn args   'make',
2023-04-26T13:53:08.986Z [err] npm ERR! gyp info spawn args   '-I',
2023-04-26T13:53:08.986Z [err] npm ERR! gyp info spawn args   '/mnt/dietpi_userdata/node-red/node_modules/spi-device/build/config.gypi',
2023-04-26T13:53:08.987Z [err] ERR! gyp info spawn args   '-I',
2023-04-26T13:53:08.987Z [err] npm ERR! gyp info spawn args   '/usr/local/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',
2023-04-26T13:53:08.987Z [err] npm ERR! gyp info spawn args   '-I',
2023-04-26T13:53:08.987Z [err] npm ERR! gyp info spawn args   '/mnt/dietpi_userdata/node-red/.cache/node-gyp/20.0.0/include/node/common.gypi',
2023-04-26T13:53:08.987Z [err] npm ERR! gyp info spawn args   '-Dlibrary=shared_library',
2023-04-26T13:53:08.987Z [err] npm ERR! gyp info spawn args   '-Dvisibility=default',
2023-04-26T13:53:08.987Z [err] npm ERR! gyp info spawn args   '-Dnode_root_dir=/mnt/dietpi_userdata/node-red/.cache/node-gyp/20.0.0',
2023-04-26T13:53:08.987Z [err] npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/usr/local/lib/node_modules/npm/node_modules/node-gyp',
2023-04-26T13:53:08.988Z [err] npm ERR! gyp info spawn args   '-Dnode_lib_file=/mnt/dietpi_userdata/node-red/.cache/node-gyp/20.0.0/<(target_arch)/node.lib',
2023-04-26T13:53:08.988Z [err]  ERR! gyp info spawn args   '-Dmodule_root_dir=/mnt/dietpi_userdata/node-red/node_modules/spi-device',
2023-04-26T13:53:08.988Z [err] npm ERR! gyp info spawn args   '-Dnode_engine=v8',
2023-04-26T13:53:08.988Z [err] npm ERR! gyp info spawn args   '--depth=.',
2023-04-26T13:53:08.988Z [err] npm ERR! gyp info spawn args   '--no-parallel',
2023-04-26T13:53:08.989Z [err] ERR! gyp info spawn args   '--generator-output',
2023-04-26T13:53:08.989Z [err] npm ERR! gyp info spawn args   'build',
2023-04-26T13:53:08.989Z [err]  ERR! gyp info spawn args   '-Goutput_dir=.'
2023-04-26T13:53:08.989Z [err]  gyp info spawn args ]
2023-04-26T13:53:08.989Z [err] npm ERR! gyp ERR! build error
2023-04-26T13:53:08.989Z [err]  ERR! gyp ERR! stack Error: not found: make
2023-04-26T13:53:08.989Z [err]  gyp ERR! stack     at getNotFoundError (/usr/local/lib/node_modules/npm/node_modules/node-gyp/node_modules/which/which.js:10:17)
2023-04-26T13:53:08.989Z [err] npm ERR! gyp ERR! stack     at /usr/local/lib/node_modules/npm/node_modules/node-gyp/node_modules/which/which.js:57:18
2023-04-26T13:53:08.990Z [err] npm ERR! gyp ERR! stack     at new Promise (<anonymous>)
2023-04-26T13:53:08.990Z [err] ERR! gyp ERR! stack     at step (/usr/local/lib/node_modules/npm/node_modules/node-gyp/node_modules/which/which.js:54:21)
2023-04-26T13:53:08.990Z [err]  gyp ERR! stack     at /usr/local/lib/node_modules/npm/node_modules/node-gyp/node_modules/which/which.js:71:22
2023-04-26T13:53:08.990Z [err] npm ERR! gyp ERR! stack     at subStep (/usr/local/lib/node_modules/npm/node_modules/node-gyp/node_modules/which/which.js:69:33)
2023-04-26T13:53:08.990Z [err] ERR! gyp ERR! stack     at /usr/local/lib/node_modules/npm/node_modules/node-gyp/node_modules/which/which.js:80:22
2023-04-26T13:53:08.991Z [err]  gyp ERR! stack     at /usr/local/lib/node_modules/npm/node_modules/isexe/index.js:42:5
2023-04-26T13:53:08.991Z [err] npm ERR! gyp ERR! stack     at /usr/local/lib/node_modules/npm/node_modules/isexe/mode.js:8:5
2023-04-26T13:53:08.991Z [err]  ERR! gyp ERR! System Linux 6.1.21-v8+
2023-04-26T13:53:08.991Z [err] ERR! gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
2023-04-26T13:53:08.991Z [err] npm ERR! gyp ERR! cwd /mnt/dietpi_userdata/node-red/node_modules/spi-device
2023-04-26T13:53:08.992Z [err] npm ERR! gyp ERR! node -v v20.0.0
2023-04-26T13:53:08.992Z [err] npm ERR! gyp ERR! node-gyp -v v9.3.1
2023-04-26T13:53:08.992Z [err] npm ERR! gyp ERR! not ok
2023-04-26T13:53:09.006Z [err]
2023-04-26T13:53:09.008Z [err] npm ERR! A complete log of this run can be found in: /mnt/dietpi_userdata/node-red/.npm/_logs/2023-04-26T13_52_58_733Z-debug-0.log
2023-04-26T13:53:09.052Z rc=1
2023-04-26T14:04:48.051Z Install : node-red-contrib-pi-max31865 0.9.4
2023-04-26T14:04:51.102Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production --engine-strict node-red-contrib-pi-max31865@0.9.4
2023-04-26T14:04:53.381Z [err] npm
2023-04-26T14:04:53.383Z [err]
2023-04-26T14:04:53.383Z [err] WARN config production Use `--omit=dev` instead.
2023-04-26T14:05:03.379Z [err] npm
2023-04-26T14:05:03.380Z [err]  ERR! code 1
2023-04-26T14:05:03.381Z [err] npm
2023-04-26T14:05:03.381Z [err] ERR! path
2023-04-26T14:05:03.384Z [err]  /mnt/dietpi_userdata/node-red/node_modules/spi-device
2023-04-26T14:05:03.392Z [err] npm ERR!
2023-04-26T14:05:03.393Z [err]  command failed
2023-04-26T14:05:03.393Z [err] npm ERR! command sh -c node-gyp rebuild
2023-04-26T14:05:03.394Z [err] npm ERR!
2023-04-26T14:05:03.394Z [err]  gyp info it worked if it ends with ok
2023-04-26T14:05:03.394Z [err] npm ERR! gyp info using node-gyp@9.3.1
2023-04-26T14:05:03.394Z [err] npm ERR! gyp info using node@20.0.0 | linux | arm64
2023-04-26T14:05:03.395Z [err]  ERR! gyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"
2023-04-26T14:05:03.397Z [err] npm ERR! gyp info spawn /usr/bin/python3
2023-04-26T14:05:03.397Z [err] npm ERR! gyp info spawn args [
2023-04-26T14:05:03.397Z [err] npm ERR! gyp info spawn args   '/usr/local/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',
2023-04-26T14:05:03.397Z [err] npm ERR! gyp info spawn args   'binding.gyp',
2023-04-26T14:05:03.397Z [err] npm ERR! gyp info spawn args   '-f',
2023-04-26T14:05:03.397Z [err] npm ERR! gyp info spawn args   'make',
2023-04-26T14:05:03.397Z [err]  ERR! gyp info spawn args   '-I',
2023-04-26T14:05:03.397Z [err] npm ERR! gyp info spawn args   '/mnt/dietpi_userdata/node-red/node_modules/spi-device/build/config.gypi',
2023-04-26T14:05:03.397Z [err] npm ERR! gyp info spawn args   '-I',
2023-04-26T14:05:03.397Z [err] npm ERR! gyp info spawn args   '/usr/local/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',
2023-04-26T14:05:03.398Z [err] ERR! gyp info spawn args   '-I',
2023-04-26T14:05:03.398Z [err] npm ERR! gyp info spawn args   '/mnt/dietpi_userdata/node-red/.cache/node-gyp/20.0.0/include/node/common.gypi',
2023-04-26T14:05:03.398Z [err] npm ERR! gyp info spawn args   '-Dlibrary=shared_library',
2023-04-26T14:05:03.398Z [err] ERR! gyp info spawn args   '-Dvisibility=default',
2023-04-26T14:05:03.398Z [err] npm ERR! gyp info spawn args   '-Dnode_root_dir=/mnt/dietpi_userdata/node-red/.cache/node-gyp/20.0.0',
2023-04-26T14:05:03.398Z [err] npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/usr/local/lib/node_modules/npm/node_modules/node-gyp',
2023-04-26T14:05:03.399Z [err] npm ERR! gyp info spawn args   '-Dnode_lib_file=/mnt/dietpi_userdata/node-red/.cache/node-gyp/20.0.0/<(target_arch)/node.lib',
2023-04-26T14:05:03.399Z [err] npm ERR! gyp info spawn args   '-Dmodule_root_dir=/mnt/dietpi_userdata/node-red/node_modules/spi-device',
2023-04-26T14:05:03.399Z [err] npm ERR! gyp info spawn args   '-Dnode_engine=v8',
2023-04-26T14:05:03.399Z [err] npm ERR! gyp info spawn args   '--depth=.',
2023-04-26T14:05:03.399Z [err] npm ERR! gyp info spawn args   '--no-parallel',
2023-04-26T14:05:03.399Z [err] ERR! gyp info spawn args   '--generator-output',
2023-04-26T14:05:03.399Z [err] npm ERR! gyp info spawn args   'build',
2023-04-26T14:05:03.399Z [err] npm ERR! gyp info spawn args   '-Goutput_dir=.'
2023-04-26T14:05:03.400Z [err]  gyp info spawn args ]
2023-04-26T14:05:03.400Z [err] npm ERR! gyp ERR! build error
2023-04-26T14:05:03.400Z [err] npm ERR! gyp ERR! stack Error: not found: make
2023-04-26T14:05:03.400Z [err] npm ERR! gyp ERR! stack     at getNotFoundError (/usr/local/lib/node_modules/npm/node_modules/node-gyp/node_modules/which/which.js:10:17)
2023-04-26T14:05:03.400Z [err] npm ERR! gyp ERR! stack     at /usr/local/lib/node_modules/npm/node_modules/node-gyp/node_modules/which/which.js:57:18
2023-04-26T14:05:03.400Z [err] npm ERR! gyp ERR! stack     at new Promise (<anonymous>)
2023-04-26T14:05:03.400Z [err] ERR! gyp ERR! stack     at step (/usr/local/lib/node_modules/npm/node_modules/node-gyp/node_modules/which/which.js:54:21)
2023-04-26T14:05:03.400Z [err] npm ERR! gyp ERR! stack     at /usr/local/lib/node_modules/npm/node_modules/node-gyp/node_modules/which/which.js:71:22
2023-04-26T14:05:03.401Z [err]  gyp ERR! stack     at new Promise (<anonymous>)
2023-04-26T14:05:03.401Z [err] npm ERR! gyp ERR! stack     at subStep (/usr/local/lib/node_modules/npm/node_modules/node-gyp/node_modules/which/which.js:69:33)
2023-04-26T14:05:03.401Z [err]  gyp ERR! stack     at /usr/local/lib/node_modules/npm/node_modules/node-gyp/node_modules/which/which.js:80:22
2023-04-26T14:05:03.401Z [err] npm ERR! gyp ERR! stack     at /usr/local/lib/node_modules/npm/node_modules/isexe/index.js:42:5
2023-04-26T14:05:03.401Z [err] npm ERR! gyp ERR! stack     at /usr/local/lib/node_modules/npm/node_modules/isexe/mode.js:8:5
2023-04-26T14:05:03.401Z [err] npm ERR! gyp ERR! System Linux 6.1.21-v8+
2023-04-26T14:05:03.401Z [err] npm ERR! gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
2023-04-26T14:05:03.402Z [err] ERR! gyp ERR! cwd /mnt/dietpi_userdata/node-red/node_modules/spi-device
2023-04-26T14:05:03.402Z [err] npm ERR! gyp ERR! node -v v20.0.0
2023-04-26T14:05:03.402Z [err]  gyp ERR! node-gyp -v v9.3.1
2023-04-26T14:05:03.402Z [err] npm ERR! gyp ERR! not ok
2023-04-26T14:05:03.420Z [err]
2023-04-26T14:05:03.421Z [err] npm
2023-04-26T14:05:03.422Z [err] ERR! A complete log of this run can be found in: /mnt/dietpi_userdata/node-red/.npm/_logs/2023-04-26T14_04_53_274Z-debug-0.log
2023-04-26T14:05:03.469Z rc=1
You have not installed the build tools.
sudo apt install build-essential
Thank you very much!!!
Everything is ok after your intervention, but I can't understand, wasn't this package installed directly with Node red, everything else is installed without a problem?
The page for getting started on pi (or Debian/Ubuntu) says:
This script will work on any Debian-based operating system, including Ubuntu and Diet-Pi . You may need to run sudo apt install build-essential git curl first to ensure npm is able to fetch and build any binary modules it needs to install.
I haven't read it anywhere. Please send me a link. Once again, I express my thanks.
Here it is - Look for the Highlighted Yellow Box
By the way, nodejs 20 is not yet supported. It may work ok for you but you may find problems. If you do then go back to 18.
How do I go back to a previous version?
Use the script from the link and add on the end
--node18
with a space before that option.
Thank you.
