Cannot order widget Switch created from subflow template
I have create a teamplate subflow with one switch wiget in subflow. I call it: "Tasmota Sonoff Dynamic":
But when I create multiple nodes from teamplate subflow (Tasmota Sonoff Dynamic):
I can not sort order wiget Switch in dardboard because In tab Layout show ONLY ONE SWITCH UI. I can not change the order by dragging.
I think the problem is the need to dynamically name the switch. But I cannot dynamically name u swtich according to environment variables like:
How to sort switches in the desired order ?
Thanks.
UI widgets are not supported inside subflows.
(I'm surprised it works that well :slight_smile:
@dceejay It works very well and smoothly. The problem is not to be sorted.
