How do I change the sequence/order of widgets from a subflow in the Dasboard 2.0? The group of the widgets in the subflow is set by env(group)...
Thank you for hints...
Hey @wangenkuesse - the best way to do this is to create the widget outside of the subflow first, order suing the Dashboard 2.0 sidebar, and then, move it into a subflow.
Currently, we aren't able to expose the order fields out of the subflow, and therefore allow control over the ordering once inside.
@Steve-Mcl may have other thoughts here, or ideas on how we could improve this?
Thanks... I tried your solution a few times. It didn't solve the problem. When I create a subflow of a selection, the order changes...
I tried to export the subflow, change the "order" field by hand and reimport it. It does not what I have expected.
How do i have do modify the order fields to get it in a desired sequence?
I was thinking about css and using "grid-order" as workaround, but some widgets do not have a "class"-field exposed...
Are you able to share a screen recording please? Subflows are still in beta for us, so we are aware of some limitations
Moved to correct category.
