Widget arrangement in a subflow
How can I change the widget arrangement within a group in node red if they are in a subflow?
A quick search of "dasboard subflow" returns this in the 1st position.
Thank you. Let's see how I can improvise.
You are right - your comment helps thx
I have got a Pull Request to review which will also add this functionality into Dashboard.
@rewegit do you need to reorder widgets within a subflow, where the subflow contains multiple widgets, or reorder the position of a subflow (which contains widgets) in a dashboard group?
I think that the PR mentioned by @joepavitt is for the the former.
@Colin I need to change the order of the widgets within a subflow when I add widgets to this subflow.
The subflow is then also a group.
The order of these groups is not a problem.
That sounds good
