I notice this topic has arisen before.
I have being experimenting with passport in Node-RED.
All seems good for OAuth and OIDC via Azure, however I am having issues with SAML.
I created an identity provider as an Enterprise app within the Azure portal.
Are there any plans to allow for SAML with a passport SAML strategy to be compatible in version 4.0.0? Or would I need to add an endpoint to listen for this POST request?
Also I notice some previous posts relating to the issue.
Can you link to these previous posts?
Any saml based passport strategy should work with Node-RED. Can you share how you have configured it (excluding any tokens of course).
No problem, thanks for having time ![:slight_smile: :slight_smile:](https://emoji.discourse-cdn.com/twitter/slight_smile.png?v=12)
This one is OIDC
However this strategy implementation for Azure works, due to the use of the parameters
responseType: "code",
responseMode: "query",
I tried those with this strategy, but they were not compatible.
I am using the SAML-P endpoint, apologies if the next code is very much Hello World!
adminAuth: {
type: "strategy",
strategy: {
label: "Sign in with Entra ID",
icon: "fa-windows",
strategy: require("passport-saml").Strategy,
options: {
issuer: "very-secret-issuer",
entryPoint: "https://login.microsoftonline.com/top-secret-uid/saml2",
cert: "almost-definitely-a-secret-cert,
callbackUrl: "http://localhost:1880/auth/strategy/callback",
verify: function (accessToken, refreshToken, profile, done) {
// @todo
done(null, profile);
autoLogin: true,
users: function (user) {
return Promise.resolve({ username: user, permissions: "*" });
Looks like more tinkering...
It was discovered that if I added the following, it worked
callbackMethod: "POST"
It's self evident but here is a link to the commit
