Cannot read property "Temperature" of undefined
I'm sure others have asked similar here before, but can anyone spot the cause of this error in the debug bar (screenshot below)?
I have used the little "copy path" button to ensure I have the correct object path. I think it may be related to "AM2301" consisting of numbers. I have also tried using square bracket notation i.e. msg.payload[AM2301].Temperature
You destroy the payload object inside the 1st if
Use else if for the 2nd if
Duh, that was obvious but I missed it :slight_smile: Thanks!
