Unless you went to the trouble of updating chrome on the PI, it is likely an old version - so not ruling out browser just yet. Lets first try bare-bones browser.
Run msedge.exe --disable-extensions on your windows box
Next, try a new node-red instance (without other contrib nodes)
Assumes you used the official PI installer script
- SSH to your PI
- stop node-red
node-red-stop - start new instance directly from terminal
node-red --userDir .node-red-clean --port 1881 - show us the start up text (sanitise anything you need to)
- open
http://pi-ip:1881in edge in windows - install flowfuse dashboard only!
- try again
PS, please post code/logs/json as a code block - see below canned text:
code goes here
icon.
I would first rule out if there is contib node causing issue
