I try to install @chvdapi/node-red-dlt645,but failed.bug report as
2025-04-09T07:13:09.324Z 安装 : @chvdapi/node-red-dlt645 0.0.4
2025-04-09T07:13:09.630Z npm.cmd install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --omit=dev --engine-strict @chvdapi/node-red-dlt645@0.0.4
2025-04-09T07:13:19.902Z [err] npm warn cleanup Failed to remove some directories [
2025-04-09T07:13:19.902Z [err] npm warn cleanup [
2025-04-09T07:13:19.902Z [err] npm warn cleanup '\\\\?\\C:\\Users\\Administrator\\.node-red\\node_modules\\@chvdapi\\node-red-dlt645\\node_modules',
2025-04-09T07:13:19.902Z [err] npm warn cleanup [Error: EPERM: operation not permitted, rmdir 'C:\Users\Administrator\.node-red\node_modules\@chvdapi\node-red-dlt645\node_modules\@serialport\bindings-cpp\prebuilds'] {
2025-04-09T07:13:19.902Z [err] npm warn cleanup errno: -4048,
2025-04-09T07:13:19.902Z [err] npm warn cleanup code: 'EPERM',
2025-04-09T07:13:19.902Z [err] npm warn cleanup syscall: 'rmdir',
2025-04-09T07:13:19.902Z [err] npm warn cleanup path: 'C:\\Users\\Administrator\\.node-red\\node_modules\\@chvdapi\\node-red-dlt645\\node_modules\\@serialport\\bindings-cpp\\prebuilds'
2025-04-09T07:13:19.902Z [err] npm warn cleanup }
2025-04-09T07:13:19.902Z [err] npm warn cleanup ]
2025-04-09T07:13:19.907Z [err] npm error code 1
2025-04-09T07:13:19.908Z [err] npm error path C:\Users\Administrator\.node-red\node_modules\@chvdapi\node-red-dlt645
2025-04-09T07:13:19.908Z [err] npm error command failed
2025-04-09T07:13:19.908Z [err] npm error command C:\WINDOWS\system32\cmd.exe /d /s /c node-gyp rebuild
2025-04-09T07:13:19.908Z [err] npm error gyp info it worked if it ends with ok
2025-04-09T07:13:19.908Z [err] npm error gyp info using node-gyp@11.2.0
2025-04-09T07:13:19.908Z [err] npm error gyp info using node@23.11.0 | win32 | x64
2025-04-09T07:13:19.908Z [err] npm error gyp info find Python using Python version 3.6.0 found at "C:\Program Files\python\python.exe"
2025-04-09T07:13:19.908Z [err] npm error gyp info find VS using VS2022 (17.13.35931.197) found at:
2025-04-09T07:13:19.908Z [err] npm error gyp info find VS "C:\Program Files\Microsoft Visual Studio\2022\Community"
2025-04-09T07:13:19.908Z [err] npm error gyp info find VS run with --verbose for detailed information
2025-04-09T07:13:19.908Z [err] npm error gyp info spawn C:\Program Files\python\python.exe
2025-04-09T07:13:19.908Z [err] npm error gyp info spawn args [
2025-04-09T07:13:19.908Z [err] npm error gyp info spawn args 'C:\\Users\\Administrator\\AppData\\Roaming\\npm\\node_modules\\npm\\node_modules\\node-gyp\\gyp\\gyp_main.py',
2025-04-09T07:13:19.908Z [err] npm error gyp info spawn args 'binding.gyp',
2025-04-09T07:13:19.908Z [err] npm error gyp info spawn args '-f',
2025-04-09T07:13:19.908Z [err] npm error gyp info spawn args 'msvs',
2025-04-09T07:13:19.908Z [err] npm error gyp info spawn args '-I',
2025-04-09T07:13:19.908Z [err] npm error gyp info spawn args 'C:\\Users\\Administrator\\.node-red\\node_modules\\@chvdapi\\node-red-dlt645\\build\\config.gypi',
2025-04-09T07:13:19.908Z [err] npm error gyp info spawn args 'C:\\Users\\Administrator\\AppData\\Roaming\\npm\\node_modules\\npm\\node_modules\\node-gyp\\addon.gypi',
2025-04-09T07:13:19.908Z [err] npm error gyp info spawn args 'C:\\Users\\Administrator\\AppData\\Local\\node-gyp\\Cache\\23.11.0\\include\\node\\common.gypi',
2025-04-09T07:13:19.908Z [err] npm error gyp info spawn args '-Dlibrary=shared_library',
2025-04-09T07:13:19.908Z [err] npm error gyp info spawn args '-Dvisibility=default',
2025-04-09T07:13:19.908Z [err] npm error gyp info spawn args '-Dnode_root_dir=C:\\Users\\Administrator\\AppData\\Local\\node-gyp\\Cache\\23.11.0',
2025-04-09T07:13:19.908Z [err] npm error gyp info spawn args '-Dnode_gyp_dir=C:\\Users\\Administrator\\AppData\\Roaming\\npm\\node_modules\\npm\\node_modules\\node-gyp',
2025-04-09T07:13:19.908Z [err] npm error gyp info spawn args '-Dnode_lib_file=C:\\\\Users\\\\Administrator\\\\AppData\\\\Local\\\\node-gyp\\\\Cache\\\\23.11.0\\\\<(target_arch)\\\\node.lib',
2025-04-09T07:13:19.908Z [err] npm error gyp info spawn args '-Dmodule_root_dir=C:\\Users\\Administrator\\.node-red\\node_modules\\@chvdapi\\node-red-dlt645',
2025-04-09T07:13:19.908Z [err] npm error gyp info spawn args '-Dnode_engine=v8',
2025-04-09T07:13:19.908Z [err] npm error gyp info spawn args '--depth=.',
2025-04-09T07:13:19.908Z [err] npm error gyp info spawn args '--no-parallel',
2025-04-09T07:13:19.908Z [err] npm error gyp info spawn args '--generator-output',
2025-04-09T07:13:19.908Z [err] npm error gyp info spawn args 'C:\\Users\\Administrator\\.node-red\\node_modules\\@chvdapi\\node-red-dlt645\\build',
2025-04-09T07:13:19.908Z [err] npm error gyp info spawn args '-Goutput_dir=.'
2025-04-09T07:13:19.908Z [err] npm error gyp info spawn args ]
2025-04-09T07:13:19.908Z [err] npm error Traceback (most recent call last):
2025-04-09T07:13:19.908Z [err] npm error File "C:\Users\Administrator\AppData\Roaming\npm\node_modules\npm\node_modules\node-gyp\gyp\gyp_main.py", line 42, in <module>
2025-04-09T07:13:19.908Z [err] npm error import gyp # noqa: E402
2025-04-09T07:13:19.908Z [err] npm error File "C:\Users\Administrator\AppData\Roaming\npm\node_modules\npm\node_modules\node-gyp\gyp\pylib\gyp\__init__.py", line 209
2025-04-09T07:13:19.908Z [err] npm error if flags := os.environ.get(env_name) or []:
2025-04-09T07:13:19.908Z [err] npm error ^
2025-04-09T07:13:19.908Z [err] npm error SyntaxError: invalid syntax
2025-04-09T07:13:19.908Z [err] npm error gyp ERR! configure error
2025-04-09T07:13:19.908Z [err] npm error gyp ERR! stack Error: `gyp` failed with exit code: 1
2025-04-09T07:13:19.908Z [err] npm error gyp ERR! stack at ChildProcess.<anonymous> (C:\Users\Administrator\AppData\Roaming\npm\node_modules\npm\node_modules\node-gyp\lib\configure.js:317:18)
2025-04-09T07:13:19.908Z [err] npm error gyp ERR! stack at ChildProcess.emit (node:events:507:28)
2025-04-09T07:13:19.908Z [err] npm error gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:294:12)
2025-04-09T07:13:19.908Z [err] npm error gyp ERR! System Windows_NT 10.0.19045
2025-04-09T07:13:19.908Z [err] npm error gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\Users\\Administrator\\AppData\\Roaming\\npm\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"
2025-04-09T07:13:19.908Z [err] npm error gyp ERR! cwd C:\Users\Administrator\.node-red\node_modules\@chvdapi\node-red-dlt645
2025-04-09T07:13:19.908Z [err] npm error gyp ERR! node -v v23.11.0
2025-04-09T07:13:19.908Z [err] npm error gyp ERR! node-gyp -v v11.2.0
2025-04-09T07:13:19.908Z [err] npm error gyp ERR! not ok
2025-04-09T07:13:19.909Z [err] npm error A complete log of this run can be found in: C:\Users\Administrator\AppData\Local\npm-cache\_logs\2025-04-09T07_13_10_053Z-debug-0.log
2025-04-09T07:13:19.923Z rc=1
