Can't install "OpenZWave" module
I want to use the "Open-ZWave" module in Node-RED.
I went to the installation directory of Node-RED, and used the following command:
$ npm install node-red-contrib-openzwave
I have this mistake:
The installation of other modules worked fine.
Have you encountered this kind of problem before?
Thank you.
Couple of things.
You are running as root, why ?
You should install it in the ~/.node-red directory
The openzwave node requires the node-openzwave library to be installed/compiled first. Did you read the documentation ?
This package has one sole dependency: node-openzwave-shared. This is a fork of node-openzwave that links to OpenZWave as a shared library , therefore you need to have the OpenZWave library installed in your system beforehand , using the operating system's package manager, or by compiling OpenZWave yourself.
Yes my installation directory was not correct on the picture.
Yes I read the documentation, but I use an ARM64 architecture, I didn't have the right libraries.
After installing the right libraries with these two commands everything worked fine:
$apt-get install openzwave
$apt-get install libopenzwave1.5-dev
Thanks for the help.
