OpenZwave Error: libopenzwave.so.1.6: cannot open shared object file
I'm trying to install Node-Red with Open-ZWave on an Ubuntu server but I seem to be running into a problem. This is likely because i'm not very experienced in Linux.
  • Ubuntu server 20.04 LTS
  • Node-Red version v1.3.4
  • Node.js version v12.22.1
  • node-red-contrib-openzwave 1.6.2
  • openzwave-shared 1.6.2
I have Node-Red and open-zwave installed. In the Node-Red palette manager I can install node-red-contrib-openzwave. However, I get a red triangle.
If I look in the log (node-red-log) i see an error:
[warn] [node-red-contrib-openzwave/zwave] Error: libopenzwave.so.1.6: cannot open shared object file: No such file or directory
What I did, step-by-step
1. Virtualbox Virtual Box 6.1.22
2. Fresh install Ubuntu server 20.04 LTS
    a) including SSH server
    b) including mosquitto
3. sudo apt update
4. sudo apt upgrade
5. Install VboxGuestAdditions 6.1.22
    a) sudo apt install build-essential dkms linux-headers-$(uname -r)
    b) sudo mount /dev/cdrom /cdrom
    c) cd /cdrom
    d) sudo sh ./VBoxLinuxAdditions.run
    e) sudo reboot
6. sudo apt install build-essential git
7. bash <(curl -sL https://raw.githubusercontent.com/node-red/linux-installers/master/deb/update-nodejs-and-nodered)
8. sudo systemctl enable nodered.service
9. git clone https://github.com/OpenZWave/open-zwave.git
10. cd open-zwave/
11. make && sudo make install && sudo ldconfig
12. npm install openzwave-shared
13. In Node-Red
    a) Manage Palette
    b) Install OpenZwave contrib
Does anybody know how I can correct this?
Your help would be greatly appreciated.
Yours sincerely,
Geuvert
How did you install libopenzwave and what does this command show?
apt policy libopenzwav*
[Edit] Just realised that you have told us how, but hidden it from immediate view.
Did you see the Notice 1 lower down the page in the open-zwave build instructions? That may be a clue as to what you have to do.
Hi Colin,
I cloned the openzwave files from git using
Then changed directory
cd open-zwave/
Build and installed everything
Install openzwave-shared via npm
And then in the palette manager in node-red I installed openzwave contrib
But reading your question, maybe I didn't install libopenzwave??
The output for apt policy libopenzwav*:
libopenzwave1.5-dev:
  Installed: (none)
  Candidate: 1.5+ds-6build1
  Version table:
     1.5+ds-6build1 500
        500 http://nl.archive.ubuntu.com/ubuntu focal/multiverse amd64 Packages
libopenzwave1.5:
  Installed: (none)
  Version table:
     1.5+ds-6build1 500
libopenzwave-doc:
  Installed: (none)
  Version table:
     1.5+ds-6build1 500
Edit
I did see this but I have not seen that specific error. If I run ld -lopenzwave --verbose, I can see that the SEARCH_DIR includes /usr/local/lib and /usr/local/lib64.
Further down I can see that eventually it succeeds in opening everything.
ld -lopenzwave --verbose output
GNU ld (GNU Binutils for Ubuntu) 2.34
  Supported emulations:
   elf_x86_64
   elf32_x86_64
   elf_i386
   elf_iamcu
   elf_l1om
   elf_k1om
   i386pep
   i386pe
using internal linker script:
/* Script for -z combreloc -z separate-code */
/* Copyright (C) 2014-2020 Free Software Foundation, Inc.
   Copying and distribution of this script, with or without modification,
   are permitted in any medium without royalty provided the copyright
   notice and this notice are preserved.  */
OUTPUT_FORMAT("elf64-x86-64", "elf64-x86-64",
              "elf64-x86-64")
OUTPUT_ARCH(i386:x86-64)
ENTRY(_start)
SEARCH_DIR("=/usr/local/lib/x86_64-linux-gnu"); SEARCH_DIR("=/lib/x86_64-linux-gnu"); SEARCH_DIR("=/usr/lib/x86_64-linux-gnu"); SEARCH_DIR("=/usr/lib/x86_64-linux-gnu64"); SEARCH_DIR("=/usr/local/lib64"); SEARCH_DIR("=/lib64"); SEARCH_DIR("=/usr/lib64"); SEARCH_DIR("=/usr/local/lib"); SEARCH_DIR("=/lib"); SEARCH_DIR("=/usr/lib"); SEARCH_DIR("=/usr/x86_64-linux-gnu/lib64"); SEARCH_DIR("=/usr/x86_64-linux-gnu/lib");
SECTIONS
  PROVIDE (__executable_start = SEGMENT_START("text-segment", 0x400000)); . = SEGMENT_START("text-segment", 0x400000) + SIZEOF_HEADERS;
  .interp         : { *(.interp) }
  .note.gnu.build-id  : { *(.note.gnu.build-id) }
  .hash           : { *(.hash) }
  .gnu.hash       : { *(.gnu.hash) }
  .dynsym         : { *(.dynsym) }
  .dynstr         : { *(.dynstr) }
  .gnu.version    : { *(.gnu.version) }
  .gnu.version_d  : { *(.gnu.version_d) }
  .gnu.version_r  : { *(.gnu.version_r) }
  .rela.dyn       :
      *(.rela.init)
      *(.rela.text .rela.text.* .rela.gnu.linkonce.t.*)
      *(.rela.fini)
      *(.rela.rodata .rela.rodata.* .rela.gnu.linkonce.r.*)
      *(.rela.data .rela.data.* .rela.gnu.linkonce.d.*)
      *(.rela.tdata .rela.tdata.* .rela.gnu.linkonce.td.*)
      *(.rela.tbss .rela.tbss.* .rela.gnu.linkonce.tb.*)
      *(.rela.ctors)
      *(.rela.dtors)
      *(.rela.got)
      *(.rela.bss .rela.bss.* .rela.gnu.linkonce.b.*)
      *(.rela.ldata .rela.ldata.* .rela.gnu.linkonce.l.*)
      *(.rela.lbss .rela.lbss.* .rela.gnu.linkonce.lb.*)
      *(.rela.lrodata .rela.lrodata.* .rela.gnu.linkonce.lr.*)
      *(.rela.ifunc)
  .rela.plt       :
      *(.rela.plt)
      PROVIDE_HIDDEN (__rela_iplt_start = .);
      *(.rela.iplt)
      PROVIDE_HIDDEN (__rela_iplt_end = .);
  . = ALIGN(CONSTANT (MAXPAGESIZE));
  .init           :
    KEEP (*(SORT_NONE(.init)))
  .plt            : { *(.plt) *(.iplt) }
.plt.got        : { *(.plt.got) }
.plt.sec        : { *(.plt.sec) }
  .text           :
    *(.text.unlikely .text.*_unlikely .text.unlikely.*)
    *(.text.exit .text.exit.*)
    *(.text.startup .text.startup.*)
    *(.text.hot .text.hot.*)
    *(SORT(.text.sorted.*))
    *(.text .stub .text.* .gnu.linkonce.t.*)
    /* .gnu.warning sections are handled specially by elf.em.  */
    *(.gnu.warning)
  .fini           :
    KEEP (*(SORT_NONE(.fini)))
  PROVIDE (__etext = .);
  PROVIDE (_etext = .);
  PROVIDE (etext = .);
  /* Adjust the address for the rodata segment.  We want to adjust up to
     the same address within the page on the next page up.  */
  . = SEGMENT_START("rodata-segment", ALIGN(CONSTANT (MAXPAGESIZE)) + (. & (CONSTANT (MAXPAGESIZE) - 1)));
  .rodata         : { *(.rodata .rodata.* .gnu.linkonce.r.*) }
  .rodata1        : { *(.rodata1) }
  .eh_frame_hdr   : { *(.eh_frame_hdr) *(.eh_frame_entry .eh_frame_entry.*) }
  .eh_frame       : ONLY_IF_RO { KEEP (*(.eh_frame)) *(.eh_frame.*) }
  .gcc_except_table   : ONLY_IF_RO { *(.gcc_except_table .gcc_except_table.*) }
  .gnu_extab   : ONLY_IF_RO { *(.gnu_extab*) }
  /* These sections are generated by the Sun/Oracle C++ compiler.  */
  .exception_ranges   : ONLY_IF_RO { *(.exception_ranges*) }
  /* Adjust the address for the data segment.  We want to adjust up to
  . = DATA_SEGMENT_ALIGN (CONSTANT (MAXPAGESIZE), CONSTANT (COMMONPAGESIZE));
  /* Exception handling  */
  .eh_frame       : ONLY_IF_RW { KEEP (*(.eh_frame)) *(.eh_frame.*) }
  .gnu_extab      : ONLY_IF_RW { *(.gnu_extab) }
  .gcc_except_table   : ONLY_IF_RW { *(.gcc_except_table .gcc_except_table.*) }
  .exception_ranges   : ONLY_IF_RW { *(.exception_ranges*) }
  /* Thread Local Storage sections  */
  .tdata          :
     PROVIDE_HIDDEN (__tdata_start = .);
     *(.tdata .tdata.* .gnu.linkonce.td.*)
  .tbss           : { *(.tbss .tbss.* .gnu.linkonce.tb.*) *(.tcommon) }
  .preinit_array    :
    PROVIDE_HIDDEN (__preinit_array_start = .);
    KEEP (*(.preinit_array))
    PROVIDE_HIDDEN (__preinit_array_end = .);
  .init_array    :
    PROVIDE_HIDDEN (__init_array_start = .);
    KEEP (*(SORT_BY_INIT_PRIORITY(.init_array.*) SORT_BY_INIT_PRIORITY(.ctors.*)))
    KEEP (*(.init_array EXCLUDE_FILE (*crtbegin.o *crtbegin?.o *crtend.o *crtend?.o ) .ctors))
    PROVIDE_HIDDEN (__init_array_end = .);
  .fini_array    :
    PROVIDE_HIDDEN (__fini_array_start = .);
    KEEP (*(SORT_BY_INIT_PRIORITY(.fini_array.*) SORT_BY_INIT_PRIORITY(.dtors.*)))
    KEEP (*(.fini_array EXCLUDE_FILE (*crtbegin.o *crtbegin?.o *crtend.o *crtend?.o ) .dtors))
    PROVIDE_HIDDEN (__fini_array_end = .);
  .ctors          :
    /* gcc uses crtbegin.o to find the start of
       the constructors, so we make sure it is
       first.  Because this is a wildcard, it
       doesn't matter if the user does not
       actually link against crtbegin.o; the
       linker won't look for a file to match a
       wildcard.  The wildcard also means that it
       doesn't matter which directory crtbegin.o
       is in.  */
    KEEP (*crtbegin.o(.ctors))
    KEEP (*crtbegin?.o(.ctors))
    /* We don't want to include the .ctor section from
       the crtend.o file until after the sorted ctors.
       The .ctor section from the crtend file contains the
       end of ctors marker and it must be last */
    KEEP (*(EXCLUDE_FILE (*crtend.o *crtend?.o ) .ctors))
    KEEP (*(SORT(.ctors.*)))
    KEEP (*(.ctors))
  .dtors          :
    KEEP (*crtbegin.o(.dtors))
    KEEP (*crtbegin?.o(.dtors))
    KEEP (*(EXCLUDE_FILE (*crtend.o *crtend?.o ) .dtors))
    KEEP (*(SORT(.dtors.*)))
    KEEP (*(.dtors))
  .jcr            : { KEEP (*(.jcr)) }
  .data.rel.ro : { *(.data.rel.ro.local* .gnu.linkonce.d.rel.ro.local.*) *(.data.rel.ro .data.rel.ro.* .gnu.linkonce.d.rel.ro.*) }
  .dynamic        : { *(.dynamic) }
  .got            : { *(.got) *(.igot) }
  . = DATA_SEGMENT_RELRO_END (SIZEOF (.got.plt) >= 24 ? 24 : 0, .);
  .got.plt        : { *(.got.plt) *(.igot.plt) }
  .data           :
    *(.data .data.* .gnu.linkonce.d.*)
    SORT(CONSTRUCTORS)
  .data1          : { *(.data1) }
  _edata = .; PROVIDE (edata = .);
  __bss_start = .;
  .bss            :
   *(.dynbss)
   *(.bss .bss.* .gnu.linkonce.b.*)
   *(COMMON)
   /* Align here to ensure that the .bss section occupies space up to
      _end.  Align after .bss to ensure correct alignment even if the
      .bss section disappears because there are no input sections.
      FIXME: Why do we need it? When there is no .bss section, we do not
      pad the .data section.  */
   . = ALIGN(. != 0 ? 64 / 8 : 1);
  .lbss   :
    *(.dynlbss)
    *(.lbss .lbss.* .gnu.linkonce.lb.*)
    *(LARGE_COMMON)
  . = ALIGN(64 / 8);
  . = SEGMENT_START("ldata-segment", .);
  .lrodata   ALIGN(CONSTANT (MAXPAGESIZE)) + (. & (CONSTANT (MAXPAGESIZE) - 1)) :
    *(.lrodata .lrodata.* .gnu.linkonce.lr.*)
  .ldata   ALIGN(CONSTANT (MAXPAGESIZE)) + (. & (CONSTANT (MAXPAGESIZE) - 1)) :
    *(.ldata .ldata.* .gnu.linkonce.l.*)
  . = ALIGN(64 / 8);
  _end = .; PROVIDE (end = .);
  . = DATA_SEGMENT_END (.);
  /* Stabs debugging sections.  */
  .stab          0 : { *(.stab) }
  .stabstr       0 : { *(.stabstr) }
  .stab.excl     0 : { *(.stab.excl) }
  .stab.exclstr  0 : { *(.stab.exclstr) }
  .stab.index    0 : { *(.stab.index) }
  .stab.indexstr 0 : { *(.stab.indexstr) }
  .comment       0 : { *(.comment) }
  .gnu.build.attributes : { *(.gnu.build.attributes .gnu.build.attributes.*) }
  /* DWARF debug sections.
     Symbols in the DWARF debugging sections are relative to the beginning
     of the section so we begin them at 0.  */
  /* DWARF 1 */
  .debug          0 : { *(.debug) }
  .line           0 : { *(.line) }
  /* GNU DWARF 1 extensions */
  .debug_srcinfo  0 : { *(.debug_srcinfo) }
  .debug_sfnames  0 : { *(.debug_sfnames) }
  /* DWARF 1.1 and DWARF 2 */
  .debug_aranges  0 : { *(.debug_aranges) }
  .debug_pubnames 0 : { *(.debug_pubnames) }
  /* DWARF 2 */
  .debug_info     0 : { *(.debug_info .gnu.linkonce.wi.*) }
  .debug_abbrev   0 : { *(.debug_abbrev) }
  .debug_line     0 : { *(.debug_line .debug_line.* .debug_line_end) }
  .debug_frame    0 : { *(.debug_frame) }
  .debug_str      0 : { *(.debug_str) }
  .debug_loc      0 : { *(.debug_loc) }
  .debug_macinfo  0 : { *(.debug_macinfo) }
  /* SGI/MIPS DWARF 2 extensions */
  .debug_weaknames 0 : { *(.debug_weaknames) }
  .debug_funcnames 0 : { *(.debug_funcnames) }
  .debug_typenames 0 : { *(.debug_typenames) }
  .debug_varnames  0 : { *(.debug_varnames) }
  /* DWARF 3 */
  .debug_pubtypes 0 : { *(.debug_pubtypes) }
  .debug_ranges   0 : { *(.debug_ranges) }
  /* DWARF Extension.  */
  .debug_macro    0 : { *(.debug_macro) }
  .debug_addr     0 : { *(.debug_addr) }
  .gnu.attributes 0 : { KEEP (*(.gnu.attributes)) }
  /DISCARD/ : { *(.note.GNU-stack) *(.gnu_debuglink) *(.gnu.lto_*) }
ld: mode elf_x86_64
attempt to open /usr/local/lib/x86_64-linux-gnu/libopenzwave.so failed
attempt to open /usr/local/lib/x86_64-linux-gnu/libopenzwave.a failed
attempt to open /lib/x86_64-linux-gnu/libopenzwave.so failed
attempt to open /lib/x86_64-linux-gnu/libopenzwave.a failed
attempt to open /usr/lib/x86_64-linux-gnu/libopenzwave.so failed
attempt to open /usr/lib/x86_64-linux-gnu/libopenzwave.a failed
attempt to open /usr/lib/x86_64-linux-gnu64/libopenzwave.so failed
attempt to open /usr/lib/x86_64-linux-gnu64/libopenzwave.a failed
attempt to open /usr/local/lib64/libopenzwave.so succeeded
libresolv.so.2 needed by /usr/local/lib64/libopenzwave.so
attempt to open /usr/lib/x86_64-linux-gnu/libfakeroot/libresolv.so.2 failed
attempt to open /usr/local/lib/libresolv.so.2 failed
attempt to open /usr/local/lib/x86_64-linux-gnu/libresolv.so.2 failed
found libresolv.so.2 at /lib/x86_64-linux-gnu/libresolv.so.2
libstdc++.so.6 needed by /usr/local/lib64/libopenzwave.so
attempt to open /usr/lib/x86_64-linux-gnu/libfakeroot/libstdc++.so.6 failed
attempt to open /usr/local/lib/libstdc++.so.6 failed
attempt to open /usr/local/lib/x86_64-linux-gnu/libstdc++.so.6 failed
found libstdc++.so.6 at /lib/x86_64-linux-gnu/libstdc++.so.6
libgcc_s.so.1 needed by /usr/local/lib64/libopenzwave.so
attempt to open /usr/lib/x86_64-linux-gnu/libfakeroot/libgcc_s.so.1 failed
attempt to open /usr/local/lib/libgcc_s.so.1 failed
attempt to open /usr/local/lib/x86_64-linux-gnu/libgcc_s.so.1 failed
found libgcc_s.so.1 at /lib/x86_64-linux-gnu/libgcc_s.so.1
libc.so.6 needed by /usr/local/lib64/libopenzwave.so
attempt to open /usr/lib/x86_64-linux-gnu/libfakeroot/libc.so.6 failed
attempt to open /usr/local/lib/libc.so.6 failed
attempt to open /usr/local/lib/x86_64-linux-gnu/libc.so.6 failed
attempt to open /usr/lib/x86_64-linux-gnu64/libc.so.6 failed
attempt to open /usr/local/lib64/libc.so.6 failed
attempt to open /lib64/libc.so.6 failed
attempt to open /usr/lib64/libc.so.6 failed
attempt to open /lib/libc.so.6 failed
attempt to open /usr/lib/libc.so.6 failed
attempt to open /usr/x86_64-linux-gnu/lib64/libc.so.6 failed
attempt to open /usr/x86_64-linux-gnu/lib/libc.so.6 failed
found libc.so.6 at /lib/x86_64-linux-gnu/libc.so.6
libm.so.6 needed by /lib/x86_64-linux-gnu/libstdc++.so.6
attempt to open /usr/lib/x86_64-linux-gnu/libfakeroot/libm.so.6 failed
attempt to open /usr/local/lib/libm.so.6 failed
attempt to open /usr/local/lib/x86_64-linux-gnu/libm.so.6 failed
found libm.so.6 at /lib/x86_64-linux-gnu/libm.so.6
ld-linux-x86-64.so.2 needed by /lib/x86_64-linux-gnu/libstdc++.so.6
attempt to open /usr/lib/x86_64-linux-gnu/libfakeroot/ld-linux-x86-64.so.2 failed
attempt to open /usr/local/lib/ld-linux-x86-64.so.2 failed
attempt to open /usr/local/lib/x86_64-linux-gnu/ld-linux-x86-64.so.2 failed
found ld-linux-x86-64.so.2 at /lib/x86_64-linux-gnu/ld-linux-x86-64.so.2
ld: warning: cannot find entry symbol _start; not setting start address
ld: /usr/local/lib64/libopenzwave.so: undefined reference to `pthread_mutexattr_destroy'
ld: /usr/local/lib64/libopenzwave.so: undefined reference to `pthread_create'
ld: /usr/local/lib64/libopenzwave.so: undefined reference to `pthread_mutex_trylock'
ld: /usr/local/lib64/libopenzwave.so: undefined reference to `pthread_condattr_setpshared'
ld: /usr/local/lib64/libopenzwave.so: undefined reference to `pthread_attr_setstacksize'
ld: /usr/local/lib64/libopenzwave.so: undefined reference to `pthread_mutexattr_settype'
ld: /usr/local/lib64/libopenzwave.so: undefined reference to `pthread_join'
ld: /usr/local/lib64/libopenzwave.so: undefined reference to `pthread_cancel'
ld: /usr/local/lib64/libopenzwave.so: undefined reference to `pthread_setname_np'
ld: /usr/local/lib64/libopenzwave.so: undefined reference to `pthread_mutexattr_init'
ld: link errors found, deleting executable `a.out'
Is suggest you ask via an issue on the node's github page.
