Can't make a 16x2 LCD Display work with Node-RED
Hello guys,
I'm new to this Node-RED world and i'm simply in love with it :slight_smile:. However i really need some help.
I would like to use a 1602 display with my Raspberry via Node-RED. I've tried doing this with three libraries:
  1. node-red-contrib-i2clcd
  2. node-red-contrib-i2c-lcd-adafruit-sainsmart
  3. node-red-contrib-lcd
The first library didn't work at all for me, i did exactly the steps mentioned in the " Install Instructions:", but the node doesn't appear in my Node-RED nodes
The second library uses I²C Serial communication, and i used a 1602 display with a I²C module with it. I know that the hardware is OK because i can easily program it with C++ or Python. However, in Node Red the following happens
When I deploy the code everything seams fine. No erros appear. In the debug output the msg.payload of the first line is shown. But as i look in the Display two diferrent things happen
When i set the manufacture to "adafruit". The light of the display becomes very dark and nothing is written:
When i set the manufacture to "sainsmart" the opossite occur:
For the last library. I get two sorts of error. First when i send a string:
And also when i send a number:
The Display node is configured as following:
This is my first Topic so i apollogize for the long post; i tried to explain every thing that happened to me. Hope anyone has a clue. Thank you very much for your attention.
P.S. For the last library example i used another 16x2 Display (without the I²C module)
Can you prove it by putting your python example scrip on a python function node?
Or can you run the example code from an Exec node to get your self a little step closer?
Hello @Brew i can't thank you enough, this worked like a charm :slight_smile:
I put a step by step tutorial in my Github repository so that other people don't waste so much time in this awsome project
