I just added the 'node-red-contrib-postgres-multi' palet but now I can't remove it / replace it even though I removed it from my flow.
Any ideas guys?
did you do a deploy before trying to remove it?
are there any config nodes for it hanging around?
Stop/start NR and see if you can remove it
if all else fails, Stop NR, change t the .node-red directory and run:
npm remove node-red-contrib-postgres-multi`
and restart Node-RED
I managed to remove it - thanks!
