Hi hope someone can help me with this error,
When i try to update a any nodes in the manage palette i get this error,
Node red version 2.0.6
npm WARN multiple-select@1.5.2 requires a peer of jquery@1.9.1 - 3 but none is installed. You must install peer dependencies yourself.
npm WARN Home_HA@0.0.1 No repository field.
npm WARN Home_HA@0.0.1 No license field.
In that case it is probably not something you are doing intentionally. I have just realised that you are probably using Home Assistant. If that is the case then it may well be an HA issue, so you may be better asking on an HA forum. Few (if any) here use HA.
You need to restart Node-RED to see updated nodes, NodeJS has no way to discard and reload nodes, so when you up date you have to restart. I am 99.9% sure there is a popup "toast" message to this effect when the update has completed.
