the Node-RED Library has more than 4000 nodes.
It's hard to find anything.
Ok, there is the search function with tags.
My suggestion is to divide the Node-RED Library into groups.
For example hardware, communication, dashboard ..
Developing websites is not easy, I know that.
But this grouping would make everything clearer.
My idea came from the forum categories.
Why not for the Node-Red Library.
Ok the tags are given in the package.json file.
There is no entry for groups or categories there.
Maybe that wasn't a good idea.
The programmer of the nodes is then to blame if he did not use the correct tags.
Then his work will not be found.
