Change a setting in the node, require re-deploy
I cannot seem to get this working. The desire is that when a user clicks a checkbox in the node's settings and then clicks Done, I want the node-red editor to require a re-deployment.
I have tried:
$("#node-input-check").on("change", () => { RED.view.dirty(true); });
But I seem to be lost.
Hi @RickyVaughn2 - Weclome to the forums
You really don't need to do that!
Given this, in your definition
defaults: {
  someCheckBox: {
    value: false,
    required: true
and ~this in your HTML
<div class="form-row">
	    <label for="node-input-someCheckBox"><i class="fa fa-line-chart"></i> Click Me</label>
	    <input type="checkbox" id="node-input-someCheckBox">
	</div>
Node RED will take care of everything - including marking the flow as requiring a publish.
any changes to the values as defined in your definition - will cause a flag to republish
Thank you for such a quick reply!
My defaults are:
pooling: { value: false, required: true },
My HTML is:
      <label for="node-input-pooling">
        <i class="fa fa-cogs"></i> Connection Pooling
      </label>
      <input type="checkbox" id="node-input-pooling" data-input-type="pooling">
    </div>
There are some other things, like disabling other settings depending on the state of this checkbox. When I check the pooling box, there is no requirement to republish. I have to move the node.
Is the issue right in front of me and I am just not seeing it, or could I be doing something else that is interfering with the republish requirement?
Unless you have a specific reason, I would remove data-input-type="pooling" - it serves no purpose with a checkbox in Node RED (as far as I'm aware) - and may cause issues actually (i'm not entirely sure).
You can store other values, but don't necessarily need to expose them to the front end.
defaults
defaults: {
  someCheckBox: {
    value: false,
    required: true
  someAffectedValue: {
    value: "",
    required: false
oneditsave
See definition properties here: HTML File : Node-RED
oneditsave: function() {
    if ($("node-input-someCheckBox").prop("checked")) {
        $("node-input-someAffectedValue").val("someValue")
HTML
<input type="hidden" id="node-input-someAffectedValue">
</div>
Outside of using a HTTP Admin Interface - the only way to commit values - is to change them
if a definition value changes - it will require a publish, if storing values outside of the definition - you need to invest using the HTTP Admin Interface
Here is my html:
  RED.nodes.registerType('mysql-r2', {
    category: 'database',
    color: '#F3B567',
    defaults: {
      name: { value: '' },
      host: { value: 'localhost' },
      database: { value: '' },
      username: { value: '' },
      password: { value: '' },
      sql: { value: '' },
      pooling: { value: false },
      waitForConnections: { value: true },
      connectionLimit: { value: 10 },
      queueTimeout: { value: 10000 },
    inputs: 1,
    outputs: 1,
    icon: 'font-awesome/fa-database',
    label: function () {
      return this.name || 'mysql-r2';
    oneditprepare: function () {
      $("#node-input-pooling").on("change", function () {
        const poolingChecked = $(this).prop("checked");
        $("#node-input-waitForConnections, #node-input-connectionLimit, #node-input-queueTimeout").prop("disabled", !poolingChecked);
      }).trigger("change");
      const inputs = [
        "name",
        "host",
        "database",
        "username",
        "password",
        "sql",
        "pooling",
        "waitForConnections",
        "connectionLimit",
        "queueTimeout",
      inputs.forEach((input) => {
        const inputElement = $(`#node-input-${input}`);
        const inputValue = this[input];
        if (inputElement.is(":checkbox")) {
          inputElement.prop("checked", inputValue);
        } else {
          inputElement.val(inputValue);
        inputElement.on("change", () => {
          this[input] = inputElement.is(":checkbox") ? inputElement.prop("checked") : inputElement.val();
</script>
<script type="text/html" data-template-name="mysql-r2">
    <label for="node-input-name">
      <i class="fa fa-tag"></i> Name
    </label>
    <input type="text" id="node-input-name" placeholder="Name">
  </div>
    <label for="node-input-host">
      <i class="fa fa-server"></i> Host
    </label>
    <input type="text" id="node-input-host" placeholder="Host/msg.host">
  </div>
    <label for="node-input-database">
      <i class="fa fa-database"></i> Database
    </label>
    <input type="text" id="node-input-database" placeholder="Database/msg.database">
  </div>
    <label for="node-input-username">
      <i class="fa fa-user"></i> Username
    </label>
    <input type="text" id="node-input-username" placeholder="Username/msg.username">
  </div>
    <label for="node-input-password">
      <i class="fa fa-lock"></i> Password
    </label>
    <input type="password" id="node-input-password" placeholder="Password/msg.password">
  </div>
    <label for="node-input-sql">
      <i class="fa fa-code"></i> SQL
    </label>
    <textarea id="node-input-sql" rows="4" placeholder="SQL/msg.sql"></textarea>
  </div>
  <hr>
    </label>
    <input type="checkbox" id="node-input-pooling">
  </div>
    <label for="node-input-waitForConnections">
      <i class="fa fa-clock-o"></i> Wait for Connections
    </label>
    <input type="checkbox" id="node-input-waitForConnections">
  </div>
    <label for="node-input-connectionLimit">
      <i class="fa fa-chain"></i> Connection Limit
    </label>
    <input type="number" id="node-input-connectionLimit" min="1" step="1">
  </div>
    <label for="node-input-queueTimeout">
      <i class="fa fa-hourglass-end"></i> Queue Timeout (ms)
    </label>
    <input type="number" id="node-input-queueTimeout" min="1" step="1">
  </div>
</script>
<script type="text/markdown" data-help-name="mysql-r2">
This Node-RED node allows you to execute MySQL queries against a specified database table.
### Configuration
The `mysql-r2` node can be configured using the following properties.
* Name: A user-friendly name for the node.
* Database: The name of the MySQL database to connect to.
* Table: The name of the table within the database to execute the query against.
* Username: The username to use to authenticate with the MySQL database.
* Password: The password to use to authenticate with the MySQL database.
* SQL: The SQL query to execute against the specified table.
* Connection Pooling: Enable or disable connection pooling.
* Wait for Connections: Determines whether the pool should wait for a connection to be available when there are no more available connections.
* Connection Limit: The maximum number of connections to create at once.
* Queue Timeout: The maximum number of milliseconds to wait before timing out when waiting for a connection to become available.
### Inputs
The `mysql-r2` node accepts a message with the following properties.
: msg.sql (string) : The SQL query to execute against the specified table. If not set, the query defined in the node configuration will be used.
: msg.host (string) : The SQL query to be used. If not set, the SQL query defined in the node configuration will be used.
: msg.database (string) : The name of the MySQL database to connect to. If not set, the database name defined in the node configuration will be used.
: msg.username (string) : The username to use to authenticate with the MySQL database. If not set, the username defined in the node configuration will be used.
: msg.password (string) : The password to use to authenticate with the MySQL database. If not set, the password defined in the node configuration will be used.
### Outputs
The `mysql-r2` node outputs a message with the following properties.
1. Standard output
: msg.payload (string) : The results of the SQL query as an array of objects. Each object in the array represents a row in the query results, with property names corresponding to the column names in the result set.
</script>
Here is my js:
module.exports = function (RED) {
    "use strict";
    const mysql = require('mysql');
    function MySQLR2Node(config) {
        RED.nodes.createNode(this, config);
        var node = this;
        var pool;
        function updateStatus() {
            if (config.pooling && pool) {
                node.status({ fill: "grey", shape: "dot", text: "pooling" });
            } else {
                node.status({ fill: "grey", shape: "dot", text: "disconnected" });
        updateStatus();
        node.on('input', function (msg) {
            var host = msg.host || config.host;
            var database = msg.database || config.database;
            var username = msg.username || config.username;
            var password = msg.password || config.password;
            var sql = msg.sql || config.sql;
            if (config.pooling && msg.hasOwnProperty('host')) {
                pool = mysql.createPool({
                    host: host,
                    user: username,
                    password: password,
                    database: database,
                    waitForConnections: config.waitForConnections,
                    connectionLimit: config.connectionLimit,
                    queueTimeout: config.queueTimeout
            var getConnection = config.pooling ? pool.getConnection.bind(pool) : (callback) => {
                var connection = mysql.createConnection({
                    host: host,
                    user: username,
                    password: password,
                    database: database
                callback(null, connection);
            node.status({ fill: "yellow", shape: "ring", text: "connecting" });
            getConnection(function (err, connection) {
                if (err) {
                    node.error(err, msg);
                    node.status({ fill: "red", shape: "dot", text: "error" });
                    if (!config.pooling) connection.end();
                    return;
                node.status({ fill: "green", shape: "dot", text: "connected" });
                connection.query(sql, function (err, rows) {
                    if (err) {
                    } else {
                        msg.payload = rows;
                        node.send(msg);
                        updateStatus();
                    if (config.pooling) {
                        connection.release();
                    } else {
                        connection.end();
    RED.nodes.registerType("mysql-r2", MySQLR2Node);
I still cannot get it to trigger a republish. I know it is something I am doing wrong, but I am not sure what it is. If you feel like it, let me know if you see something. I am just going to push this out with the known issue and hopefully someone might help fix it.
It is for this
Thank you :slight_smile:
