Change field name
How can I turn a field name into a payload?
I have a LoraWan node that sends GPS coordinates via TTN to Cayenne. I want to use the same payload also in Node-red but to do so I need to change the field names latitude and longitude to lat and lon.
you can use a change node to move values from one msg property to another.
So use a change node that has something like this:
Johannes
Thanks, so simple. I was using Change...
