Hi, I need to change the flow file path. I don´t Know how to do it. any help will be greatly appreciated.
Thanks Lucas
You can set the full path to the file in C:\Users\x6294075\.node-red\settings.js - you should find a flowFile entry that you can edit.
Solved, thank you very much
Or you can include it in the command line
node-red path/to/flows/file
