How to set the flows_cred.json location?
In my settings.js file I have set flowFile: '/data/node-red/flows.json',
The flows.json file is now located in /data/node-red/. This works as expected, but I also expected the flows_cred.json file to be located in the same folder. That's not the case. It is still stored to /home/username/.node-red/. But the filename is changed to flows_cred.json, instead of flows__cred.json. How can i change the path to the flows_cred.json file?
I am using node-red v0.19.5
Hi @jostor, welcome to the forum.
Node-RED will always place the credentials file in the user data directory, alongside the other user files. There is no option available to have it saved somewhere else.
Thanks for your reply and explanation.
I see that it is possible to use another user data directory. Either by setting it in settings.js with userDir or by starting node-red with the --userDir option. Isn't that correct?
If I have an already running system where userDir is set to default (/home/user/.node-red/), and I want to move the userDir to /data/node-red/, can I just move all the files from /home/user/.node-red/ to /data/node-red/ and start node-red with the --userDir /data/node-red/ option? Or will this fail in any way?
Yes. Make sure you include the hidden files in /home/user/.node-red/ - those that begin with a . such as .config.json.
Thanks! I will try.
Also, obviously, the user running node red will have to have full access to that folder.
Rather than moving the files you could make /data/node-red be a link to the existing .node-red folder, though that may not be appropriate for your requirements. It can make life simpler when it comes to updating node red for example.
