Change label field in Dashboard2 and ui_chart
I want to use ui-chart in a subflow, but how can I change the "Label" field in ui-chart with Dashboard2 ?
It doesn't work with msg.ui_update.label
In Dashboard1 the label could be changed by using {{msg.xxx}}
Is it possible to also change the "Y-Axis Label" ?
Is it possible to set the value for "Y-Axis min" and "Y-Axis max" ?
I've read the documentation at Chart ui-chart | Node-RED Dashboard 2.0
