This code does not work, neither ymax, xmin nor label are changed.
What is the correct solution?
Welcome to the forum @lbarjak
Feed the function into a debug node set to Output Complete Message and show us what it says.
Hello Colin,
object
topic: "BBB"
payload: 150
_topic: "data"
_msgid: "8b9245b2a399b5b6"
ymin: 0
ymax: 300
state: "BBB"
ui_update: object
options: object
scales: object
y: object
min: 0
max: 300
label: "something"
I don't think the chart accepts dynamic properties for those values (not yet anyway). I don't see it mentioned in the node's help text or the documentation.
No indeed nothing in the code of the ui-chart node to support dynamic properties.
Personally I wouldn't add to much new features to the ui-chart node now, because that will make it even more difficult to migrate from ChartJs to Echarts (see this issue). Even now, such a refactoring will be not an easy job...
Fooled by AI ![]()
It is always worth checking the docs when something doesn't work as expected.
As a last resort, yes.
Has it occurred to you that by asking here rather than checking the docs yourself you wasted my time checking the docs for you and @BartButenaers' time checking the code?
Yes, I was joking. Thanks for your help.
My conclusion:
I have had good experience with the svgjs library in other areas, so I will use it for the diagrams.
