Change node - outputs: 0
I use change nodes to set flow/global variables and would like to visually see the "end" of the flow.
In function nodes, one can set the number of outputs to 0.
Would something like this be possible for the change node too, in the appearance tab for example ?
Side note, i noticed that the node color in the appearance tab is gone, is this correct (could have been gone for a while, just noticed it).
Colour was only there in the appearance tabs for subflows. It was never there for normal nodes.
