I have a weird issue. I am running version 5.0.8 in a container managed by Podman and have been running node-red with periodic updates for several years and in the last month I have had a very weird issue some up.
Any edits to the flows via the UI, no matter how simple, will not save. As an example, I add a debug node and hook it up then click the "Deploy" button. If I then refresh the web page, the change will be gone. This applies to any flow change, deletions, additions or even just moving on the canvas are lost. I can add new items to the palette without any problem whatsoever.
No intentional changes have been made to the setup or file permissions.
I am not seeing anything in the logs, but the logging level might not be set correctly. All existing flows operate correctly.
Help please!
