Is there a way to address a specific Comment-node via a Function-Node code to alter it's name?
X
I think I know the the answer; and it's NO.; one can only change the "status".
X
Hi @xytsrm
That is correct. One node cannot modify another node's configuration.
Thanks for the confirmation & suggestions.
What I was looking for was a node I could use as a Flow title that could change and reflect the status, or state of the Flow as it operated. The Debug pane is not useful, as the information scrolls.
X.
Hi krambriw,
Thanks for the suggestion. I actually tried the "status" trick. ; it just isn't large enough. It's too bad something like a Banner-Node doesn't exist, where messages sent to it get displayed. It should also have properties that can affect Font-size and color, as well as background color. Also, some nodes like suncalc can be directly accessed accessed via code rather than wired; it seems if a node's data can be read, data could be written.
Oh well; I can dream - lol
If you then would use a function node like I do and set 0 outputs, seems it does not have that 32 char limitation, could maybe be a solution to accept
If not, there are always the possibility to contribute with a new node to share, maybe you could start with a clone or copy of the normal comment node and add an input to it
Would you not be better to use node-red-dashboard for showing the ongoing status? That is what it is for.
What do you mean by using the dashboard for showing the status?
Rather than trying to use the editor as a dashboard, use the dashboard.
From the Node-Red site on the Dashboard:
NOTE: This project is based on Angular v1 - As that is now no longer maintained, this project should be considered to be on "life support". Small patches will be applied on a best can do basis, but there will be no major feature upgrades, and underlying security breakage may occur.
Also, it would not be useful for my intended purpose.
