Changing node change a number
I have a short question for my heating system at home.
I have set temperatures from 10 to 30 degreed.
if the set value is under 18, then the changing node have to change it to 18 back.
        "id": "aa53b2534b60a64a",
        "type": "inject",
        "z": "1a0d5b259b9dac43",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "21",
        "payloadType": "num",
        "x": 270,
        "y": 320,
                "2a5315906043b90c",
                "de30d778c529f126"
        "id": "7beaf9a86a98fcf5",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "16",
        "x": 270,
        "y": 400,
                "2a5315906043b90c",
                "de30d778c529f126"
        "id": "2cbe9c7f1177aefb",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "18",
        "x": 270,
        "y": 360,
                "2a5315906043b90c",
                "de30d778c529f126"
        "id": "9be09b68b1d93474",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "10",
        "x": 270,
        "y": 440,
                "2a5315906043b90c",
                "de30d778c529f126"
        "id": "de30d778c529f126",
        "type": "switch",
        "name": "kleiner als 18 Grad C",
        "property": "payload",
        "propertyType": "msg",
        "rules": [
                "t": "gte",
                "v": "18",
                "vt": "num"
                "t": "btwn",
                "v": "10",
                "vt": "num",
                "v2": "17.5",
                "v2t": "num"
        "checkall": "true",
        "repair": false,
        "outputs": 2,
        "x": 460,
        "y": 320,
                "bc7671eb38bb8daf"
                "f6bdaf5b322e92f8"
        "id": "bc7671eb38bb8daf",
        "type": "debug",
        "name": "Auto und Kühlen",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": true,
        "complete": "payload",
        "targetType": "msg",
        "statusVal": "payload",
        "statusType": "auto",
        "x": 950,
        "y": 340,
        "id": "f6bdaf5b322e92f8",
        "type": "change",
        "name": "10-17.5 = 18",
        "rules": [
                "t": "change",
                "p": "payload",
                "pt": "msg",
                "from": "payload",
                "fromt": "msg",
                "to": "18",
                "tot": "num"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 630,
        "y": 380,
                "bc7671eb38bb8daf"
How I can realize that?
Instead of using change in the change node, just use set msg.payload to number 18 ?
Oh my goodness. That is so easy. I doubt know, why I couldn't find them. Thanks again. Issue closed and have a N.I.C.E. day
