Chart on dashboard 2 with multiline: the first 2 point are connected only for the first line
I send multiple msg to chart using a function
the function is
const v=msg.payload.split(',')
let gpc = []
let x=context.get('x')
x=x===undefined?1:++x
context.set('x',x)
for (let i = 1; i < 9; i++) {
    const val = i*4 + v[i+5]
    gpc.push({ topic: "t" + i, payload: {x:x, v:val} })
return [gpc]
the message sent to the chat are :
{"topic":"t1","payload":{"x":2,"v":6},"_msgid":"2279f52ad5738a66"}
{"topic":"t2","payload":{"x":2,"v":10},"_msgid":"2279f52ad5738a66"}
{"topic":"t1","payload":{"x":3,"v":6},"_msgid":"b59dd85692696016"}
{"topic":"t2","payload":{"x":3,"v":10},"_msgid":"b59dd85692696016"}
I got this
any ideas?
Hi and welcome. :slight_smile:
Slight suggestion.
When pasting code, please format it correctly.
Click the button in the top that looks like </>
type or paste code here
Then put the code where it says.
It is better as the second like in your code is corrupted
let gpc = (square box)
So something is going on there.
Thank's a a lot for the hints
the code is
let gpc = []
context.set('x',x)
    const val = i*4 +v[i+5]
return [gpc]
the message get form mqtt serv are like
"0,0,8,0,0,0,2,2,2,2,2,2,2,2"
the chart conf:
HI there seems to be a few bugs i have notice here.
I think you should check the nodes github page and check to see if issues have been raised, if not raise them.
First - The point is plotted but no line drawn after any topic after first. As you have highlighted
Second - When you hover over a y axis point not all topic points that correspond to that point ar shown. You have to move mouse over each individually, This maybe by design, but for a line chart I think all corresponding topics should be shown
Third - There appears to be no msg or string type input on y property input, this maybe a browser issue, is anyone else seeing this (chrome android).
Tagging @joepavitt
reported
feature request
Thank youu @E1cid !
No problem.
Just to add you can send the chart an array of objects in one message rather than multiple.
This example also contains a workaround till issue is fixed
e.g.
[{"id":"98571d07252f3e61","type":"inject","z":"d1395164b4eec73e","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[\"0,0,8,0,0,0,2,2,2,2,2,2,2,2\",\"0,0,8,0,0,0,2,2,2,2,2,2,2,2\",\"0,0,8,0,0,0,2,2,2,2,2,2,2,2\",\"0,0,8,0,0,0,2,2,2,2,2,2,2,2\"]","payloadType":"json","x":130,"y":100,"wires":[["3ae1dd08967d2334"]]},{"id":"3ae1dd08967d2334","type":"split","z":"d1395164b4eec73e","name":"simulate mqtt","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":280,"y":100,"wires":[["59965e5b7592fb31"]]},{"id":"59965e5b7592fb31","type":"function","z":"d1395164b4eec73e","name":"function 157","func":"\nconst v=msg.payload.split(',')\nlet gpc = []\n\nlet x = context.get('x') ?? 0\nx++\ncontext.set('x',x)\n\nfor (let i = 1; i < 9; i++) {\n    const val = i*4 +v[i+5]\n    gpc.push({x:x, v:val, series: \"t\" + i} )\n}\nmsg.payload = gpc\n\nif(x===1){\n    let null_array = []\n    for (let i = 1; i < 9; i++) {\n        const val = i * 4 + v[i + 5]\n        null_array.push({ x: x, v: null, series: \"t\" + i })\n    }\n    node.send({payload:null_array})\n}\nreturn msg","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":470,"y":160,"wires":[["f11b0e84da884431","c7b8e797bf25ce1e"]]},{"id":"f11b0e84da884431","type":"debug","z":"d1395164b4eec73e","name":"debug 2565","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":650,"y":100,"wires":[]},{"id":"c7b8e797bf25ce1e","type":"ui-chart","z":"d1395164b4eec73e","group":"ff7cbf009b7b3034","name":"","label":"chart","order":5,"chartType":"line","category":"series","categoryType":"property","xAxisLabel":"","xAxisProperty":"x","xAxisPropertyType":"property","xAxisType":"linear","xAxisFormat":"s","xAxisFormatType":"custom","yAxisLabel":"","yAxisProperty":"v","ymin":"","ymax":"","action":"append","stackSeries":false,"pointShape":"false","pointRadius":4,"showLegend":true,"removeOlder":1,"removeOlderUnit":"3600","removeOlderPoints":"","colors":["#0095ff","#ff0000","#ff7f0e","#2ca02c","#a347e1","#d62728","#ff9896","#9467bd","#c5b0d5"],"textColor":["#666666"],"textColorDefault":true,"gridColor":["#e5e5e5"],"gridColorDefault":true,"width":6,"height":8,"className":"","x":570,"y":240,"wires":[[]]},{"id":"dac39029fdd65c11","type":"inject","z":"d1395164b4eec73e","name":"","props":[{"p":"payload"},{"p":"action","v":"replace","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[]","payloadType":"json","x":290,"y":260,"wires":[["c7b8e797bf25ce1e"]]},{"id":"ff7cbf009b7b3034","type":"ui-group","name":"Form","page":"3bceecc44f91d26b","width":"6","height":"1","order":1,"showTitle":true,"className":"","visible":"true","disabled":"false"},{"id":"3bceecc44f91d26b","type":"ui-page","name":"Custom Form Submission","ui":"1805777f90e92057","path":"/form-submission","icon":"home","layout":"grid","theme":"35ee7753b5b3599b","order":1,"className":"","visible":true,"disabled":false},{"id":"1805777f90e92057","type":"ui-base","name":"dashboard","path":"/dashboard","includeClientData":true,"acceptsClientConfig":["ui-notification","ui-control"],"showPathInSidebar":false},{"id":"35ee7753b5b3599b","type":"ui-theme","name":"Theme Name","colors":{"surface":"#16234b","primary":"#1d44b9","bgPage":"#ecf2f8","groupBg":"#ffffff","groupOutline":"#cccccc"}}]
msg.payload
        "x": 10,
        "v": "42",
        "series": "t1"
        "x": 10,
        "v": "82",
        "series": "t2"
        "x": 10,
        "v": "122",
        "series": "t3"
        "x": 10,
        "v": "162",
        "series": "t4"
        "x": 10,
        "v": "202",
        "series": "t5"
        "x": 10,
        "v": "242",
        "series": "t6"
        "x": 10,
        "v": "282",
        "series": "t7"
        "x": 10,
        "v": "322",
        "series": "t8"
Function
let gpc = []
x++
context.set('x',x)
    gpc.push({x:x, v:val, series: "t" + i} )
msg.payload = gpc
if(x===1){
    let null_array = []
        null_array.push({ x: x, v: null, series: "t" + i })
return msg
Thank U a lot!
It works fine!
Jus add a cls/reset
const t=msg.topic
if (t === 'cls') {
    context.set('x', 0);
    return null
const v = msg.payload.split(',')
let gpc = []
x++
context.set('x', x)
    const val = i*4 +1.0*v[i+5]
    gpc.push({ x: x, v: val, series: "t" + i })
msg.payload = gpc
if (x === 1) {
    let null_array = []
        const val = i * 4 + 1.0*v[i + 5]
    node.send({ payload: null_array })
return msg
        "id": "59965e5b7592fb31",
        "type": "function",
        "z": "c0791a4b1d1825e1",
        "name": ".",
        "func": "const t=msg.topic\n\nif (t === 'cls') {\n    context.set('x', 0); \n    return null\n    }\n\nconst v = msg.payload.split(',')\nlet gpc = []\n\nlet x = context.get('x') ?? 0\nx++\ncontext.set('x', x)\n\nfor (let i = 1; i < 9; i++) {\n    const val = i*4 +1.0*v[i+5]\n    gpc.push({ x: x, v: val, series: \"t\" + i })\n}\nmsg.payload = gpc\n\nif (x === 1) {\n    let null_array = []\n    for (let i = 1; i < 9; i++) {\n        const val = i * 4 + v[i + 5]\n        null_array.push({ x: x, v: null, series: \"t\" + i })\n    }\n    node.send({ payload: null_array })\n}\nreturn msg",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 430,
        "y": 300,
                "c7b8e797bf25ce1e"
        "id": "c7b8e797bf25ce1e",
        "type": "ui-chart",
        "group": "2b122ee2150554cb",
        "name": "WO",
        "label": "chart",
        "order": 5,
        "chartType": "line",
        "category": "series",
        "categoryType": "property",
        "xAxisLabel": "",
        "xAxisProperty": "x",
        "xAxisPropertyType": "property",
        "xAxisType": "linear",
        "xAxisFormat": "s",
        "xAxisFormatType": "custom",
        "yAxisLabel": "",
        "yAxisProperty": "v",
        "ymin": "",
        "ymax": "",
        "action": "append",
        "stackSeries": false,
        "pointShape": "false",
        "pointRadius": 4,
        "showLegend": true,
        "removeOlder": 1,
        "removeOlderUnit": "3600",
        "removeOlderPoints": "",
        "colors": [
            "#0095ff",
            "#ff0000",
            "#ff7f0e",
            "#2ca02c",
            "#a347e1",
            "#d62728",
            "#ff9896",
            "#9467bd",
            "#c5b0d5"
        "textColor": [
            "#666666"
        "textColorDefault": true,
        "gridColor": [
            "#e5e5e5"
        "gridColorDefault": true,
        "width": "22",
        "height": "7",
        "className": "",
        "x": 590,
        "y": 340,
        "id": "dac39029fdd65c11",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "action",
                "v": "replace",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "1",
        "payloadType": "num",
        "x": 130,
        "y": 340,
                "2988c92b9989cebe"
        "id": "32bd46a4d0312454",
        "type": "mqtt in",
        "topic": "lenovo/17",
        "qos": "2",
        "datatype": "auto-detect",
        "broker": "6887952d93610996",
        "nl": false,
        "rap": true,
        "rh": 0,
        "inputs": 0,
        "x": 240,
        "y": 260,
                "59965e5b7592fb31"
        "id": "2988c92b9989cebe",
        "type": "ui-button",
        "name": "CLS",
        "label": "button",
        "order": 1,
        "width": 0,
        "height": 0,
        "emulateClick": true,
        "tooltip": "",
        "color": "",
        "bgcolor": "",
        "className": "",
        "icon": "",
        "iconPosition": "left",
        "payload": "[]",
        "payloadType": "json",
        "topic": "cls",
        "topicType": "str",
        "buttonColor": "",
        "textColor": "",
        "iconColor": "",
        "x": 250,
        "y": 340,
                "59965e5b7592fb31",
                "c7b8e797bf25ce1e"
        "id": "2b122ee2150554cb",
        "type": "ui-group",
        "name": "Lenovo",
        "page": "ed0c097b7d2f4e94",
        "width": "22",
        "height": "1",
        "order": 1,
        "showTitle": true,
        "className": "",
        "visible": "true",
        "disabled": "false"
        "id": "6887952d93610996",
        "type": "mqtt-broker",
        "name": "tfqm",
        "broker": "172.27.1.100",
        "port": "8883",
        "tls": "",
        "clientid": "",
        "autoConnect": true,
        "usetls": true,
        "protocolVersion": "4",
        "keepalive": "60",
        "cleansession": true,
        "autoUnsubscribe": true,
        "birthTopic": "",
        "birthQos": "0",
        "birthRetain": "false",
        "birthPayload": "",
        "birthMsg": {},
        "closeTopic": "",
        "closeQos": "0",
        "closeRetain": "false",
        "closePayload": "",
        "closeMsg": {},
        "willTopic": "",
        "willQos": "0",
        "willRetain": "false",
        "willPayload": "",
        "willMsg": {},
        "userProps": "",
        "sessionExpiry": ""
        "id": "ed0c097b7d2f4e94",
        "type": "ui-page",
        "name": "L2",
        "ui": "0b41aa48339b29b0",
        "path": "/page4",
        "icon": "home",
        "layout": "grid",
        "theme": "eeb23137d2f23736",
        "order": 1,
        "className": "",
        "visible": "true",
        "disabled": "false"
        "id": "0b41aa48339b29b0",
        "type": "ui-base",
        "name": "My Dashboard",
        "path": "/dashboard",
        "includeClientData": true,
        "acceptsClientConfig": [
            "ui-notification",
            "ui-control"
        "showPathInSidebar": false,
        "navigationStyle": "default"
        "id": "eeb23137d2f23736",
        "type": "ui-theme",
        "name": "Default Theme",
        "colors": {
            "surface": "#ffffff",
            "primary": "#0094CE",
            "bgPage": "#eeeeee",
            "groupBg": "#ffffff",
            "groupOutline": "#cccccc"
        "sizes": {
            "pagePadding": "12px",
            "groupGap": "12px",
            "groupBorderRadius": "4px",
            "widgetGap": "12px"
