Check the use of nodes in flows
I want to cleanup my installed nodes.
Is there a way to check if an installed node in the palette is use by flows ?
If you open the Palette Manager in the editor, under the Nodes tab it lists all of the modules installed and shows if they are in-use or not.
Are the nodes that are NOT used, the ones that show remove or disable
Correct. The Palette manager will only let you remove or disable node modules you are not using.
ahh, Great. I did not interpretate this as unused...
Thanks, now i am gonna cleanup :slight_smile:
