clearTimeout not function
Hi, I'm new here, I'm trying to use clearTimeout, but it doesn't work, I guess I'm doing something wrong.
This is my code
var entrada = msg.payload;
var testset;
if(entrada == "on"){
    testset = setTimeout(function() {
        msg.payload = "active";
        node.send(msg);
    }, 2000);
if (entrada == "off"){
    clearTimeout(testset);
I would greatly appreciate any help in learning.
Every time a function runs, everything is executed from top to bottom. Variables do not persist.
You can do this with context (to store the timer handle) but the question is why??? There is a delay node built-in to node-red.
Like this @wilson2517 ...
var testset = context.get("testset");  // Retrieve the stored timeout reference
if (entrada == "on") {
        node.send(msg);
    }, 2000);
    context.set("testset", testset);  // Store the timeout reference for future use
if (entrada == "off") {
    clearTimeout(testset);  // Clear the timeout
    context.set("testset", null);  // Clear the stored timeout reference
Wow!!!! I'm learning THX
In case you were wondering @wilson2517 ...
[{"id":"6214978a5e43666b","type":"switch","z":"be4568a984cb4685","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"on","vt":"str"},{"t":"eq","v":"off","vt":"str"}],"checkall":"false","repair":false,"outputs":2,"x":430,"y":2100,"wires":[["0ff3f2b1da3f439e"],["92b4608997303baf"]]},{"id":"92b4608997303baf","type":"debug","z":"be4568a984cb4685","name":"debug 2482","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":750,"y":2100,"wires":[]},{"id":"0ff3f2b1da3f439e","type":"delay","z":"be4568a984cb4685","name":"","pauseType":"delay","timeout":"2","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":560,"y":2080,"wires":[["92b4608997303baf"]]},{"id":"bf5f509eb2d579fb","type":"inject","z":"be4568a984cb4685","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"on","payloadType":"str","x":250,"y":2080,"wires":[["6214978a5e43666b"]]},{"id":"8378a2e9f3699002","type":"inject","z":"be4568a984cb4685","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"off","payloadType":"str","x":250,"y":2120,"wires":[["6214978a5e43666b"]]}]
yes, I know, but clearTimeout stop fire command of setTimeout, delay is for other thing.
The point is that you don't need to use setTimeout at all. You can use a Delay node instead.
Yes I know, setTimeout and clearTimeout is for specific use, delay is normal for me.
