Clickable items in table-ui Dashboard 2.0
I am working with a table within dashboard 2.0 using the ui-template as described here. here I am wondering if anyone knows if there is a way I can create clickable items within the table or even add a button. I have tried:
    <template v-slot:item.action="{ item }">
        <v-btn small @click="buttonAction(item)">Click Me</v-btn>
    </template>
but to no avail. Thanks
Hi @mtech171 - welcome to the community!
Two options:
  • As you have it: I'm not seeing anything obviously wrong, although, is this snippet in the context of a full v-data-table?
  • Native Functionality: I have a draft PR which will be adding a new config to the ui-table and enable them to be clickable and will emit the full item from the node. That should go into the library this week.
