Clone a previous configuration: restore flows_raspberrypi.json is enough?
Hi mates, yesterday for the first time I restored flow from a clipboard backup. All was fine exept one module, which communicates with Amazon Echo.
After the restore Alexa couldn't control more the modules, I think because the module sent to her its node ID during the first discovery, she saved it and send that ID on every object, when I restore a flow NR gives to the same nodes other IDs, and this is why it doesn't work I suppose. I should on Alexa delete devices and search again all.
My questions are:
Is enough to copy flows_raspberrypi.json and overwrite it back to have a perfect clone of what was running before? (of course close browser page aand reload it after the overwrite.). Any other file to restore?
I always had the problem to find the node ID number of every node in the flow, I can only know it if a message error is created by a module without a name and I see it in the debug window. Can you please introduce in NR a chance to see its ID on the node window property? Thanks
Just had to re-install myself.
flows_rasperrypi.json gets you so far but the additional nodes are in package.json which won't import so I needed to manually add them to the Pallette
Welcome to the forum.
If you had restored package.json and gone into the .node-red folder and run npm install then that should have installed everything you need.
If you want to restore exactly the same versions of nodes then also restore package-lock.json before running install.
As I said, I couldn't load the package.json because Node-Red said that something in the file wasn't json compliant.
Having said that I was surprised that I couldn't find anything in the docs about restoring and the post I was replying to was 18 months old without any replies.
