Cloning Project from github to windows PC
I am trying to clone a project i pushed from my Node-red Unbuntu server onto Git but now would like to clone it onto my Windows 10 PC. I keep getting authentication failure.
I am not sure of which information i am to put into which fields and what is my credential key etc.
Hope this makes sense i am new to projects
Or as a footnote is there an easier way to get a copy of what is running on my server to run on my windows PC and also keep each in sync with each other?
Thanks in anticipation
Could be unrelated but I was trying to install contrib node from GitHub and getting authentication failures 2 days ago.
I then got an email from GitHub that said something about a token being deprecated and I needed to update it
I followed the instructions and now I'm sorted
Might not help you but though I better pass it on just in case its the same thing
thanks @cymplecy but i did the 2 stage authentication with github do not think that is the issue here,
but will look into it. personally i just think its my lack of knowledge :slight_smile:
Thanks @cymplecy turns out you were 100% correct, and entering the token where the password should go worked!
