I hope this is simple. I'm reading a value from a tag that has an integer value. I need to pass that into command factory to a multi-level switch to control dimness. I get an error that it needs to be an array. How do I format that. If I use an inject with a value of "[40]" that works?
No, not at all!
Welcome to the forum, but your explanation is not clear.
What is a tag?
What is command factory?
What is the error?
Copy/paste the error.
Please explain in more detail what your issue is.
Never mind. I figured it out. Had to put payload in brackets.
