I have created a Vite Vue.js 3 project, and with the help of vite-plugin-singlefile, I can build the project into a single file. What I want to do is serve this file with the dashboard-20 template node.
I can't get it to work. My single file is a standalone, full HTML with minimized JS and a body tag like this:
<body>
<div id="app"></div>
</body>
I selected the template group and tried all the types, but nothing seems to work. Has anyone tried this before? What am I missing?
Thanks in advance.
Regards,
Nuri
may i know how exactly you tried to do it?
you took a ui-template node and inside within tag pasted your standalone file ?
Yes. I build the code into single file html. I copy and paste this html into dashboard-20 template node. I did it like this with standard template node and http in nodes before.
Do you need the support of D2? Or would UIBUILDER be a better approach given that it would offer support without the complexities and overheads of D2?
UIBUILDER allows for a build-step and lets you switch from a default src un-built version to a dest (or other folder) built-version. Currently, you would do the build process outside Node-RED itself though there are plans in the backlog for the uibuilder node to pick up defined script's in your uibuilder instance folder's package.json and offer buttons in Node-RED to run the build.
UIBUILDER: Front-End Build Steps and Tools
