Uibuilder template doesn't work
Hi fellas,
sorry if my question was already asked. But i couldn't find anything regarding my issue.
I'm running node-red in a docker and I wanted to build my own custom dashboard without using the common buttons and input nodes. Therefore I've installed the uibuilder. The template I choosed is
VueJS and bootstrap-vue
I've installed the following libraries
  1. [bootstrap], 4.6.1
    URL to use: "../uibuilder/vendor/bootstrap/dist/js/bootstrap.js"
  2. [bootstrap-vue], 2.22.0
    URL to use: "../uibuilder/vendor/bootstrap-vue/./dist/bootstrap-vue.common.js"
  3. [cloak], 1.0.0
    URL to use: "../uibuilder/vendor/cloak/index.js"
  4. [svelte], 3.48.0
    URL to use: ../uibuilder/vendor/svelte/index
  5. [vue], 3.2.37
    URL to use: ../uibuilder/vendor/vue/dist/vue.global.js
But if I try to load the dashboard example its showing nothing, just a empty site.
If I comment out the [v-cloak] { display: none; } in the index.css it seems to work, but anyway it shows than everywhere the msg-input field {{msg....}}
My guess is, that this has something to do with the index.js can not be loaded?
Someone faced that issue too?
You don't need that, it is a different framework.
Bootstrap-vue only works with vue v2. You can install that via uibuilder's library tab, simply add a new entry for vue@2 and it will replace Vue v3.
You also don't actually need to install bootstrap since bootstrap-vue does that for you. But it doesn't harm anything.
Hello!
Thanks for the fast reply! I just installed the vue v2 and dropped the other libraries. It works now!
Love it. Thanks for your time and help! :slight_smile:
